Hallo. Ein Anfänger braucht Hilfe!
Ich habe 2 Picdem Z boards und möchte einen intergrierten Sensor (TC77)
abfragen. Ich möchte diese Funktion in das Demoprogramm einbinden. Im
Mikrochip Forum habe ich eine Funktion (C-Programm) gefunden, die ich
nutzen will. Die Funktion sieht wie folgt aus: (Frage hierzu folgt im
Anschluss)
#include "generic.h"
#include "TC77.h"
#include "Console.h"
#include "string.h"
#include "MSPI.h"
#define TC77_CS LATA2
* Function: BYTE GetTC77String( char *buffer )
* PreCondition: None
* Input: buffer - pointer where to store the string.
* Output: The length of the returned string.
* Side Effects: None
* Overview: This function reads the TC77 and returns a
formatted
* temperature value at *buffer. If we get a 0x00
* or 0xFF, we report that we are having a problem
* with the temperature sensor.
* Note:
typedef union _SIGNED_WORD_VAL
unsigned int uVal;
int Val;
struct
BYTE LSB;
BYTE MSB;
} byte;
} SIGNED_WORD_VAL;
BYTE GIEHsave;
char *ptr;
char *pTempString;
SIGNED_WORD_VAL RawTemp;
signed long ScaledTemp;
BYTE strLen;
char tempString[10];
// Read the temperature from the TC77
// The TC77 gives a left aligned 13 bit signed integer
// where 0 = 0 degrees Celcius, 1 = 0.0625 degrees,
// 2 = 0.125 degrees, -1 = -0.0625 degrees,
// -2 = -0.125 degrees, 400 = 25 degrees, etc.
// To convert it to a usable value, one should
// right align it and then sign extend it. For human
// display purposes, one should either convert it to a
// floating point number and multiply it by 0.0625
// degrees C. Alternatively, it may be left as an integer
// and multiplied by 625. The result would be scaled by
// a factor of 10,000.
// Disable interrupts while we talk to the temperature sensor.
GIEHsave = GIEH;
GIEH = 0;
// Read data from the TC77
TC77_CS = 0; // Select TC77
RawTemp.byte.MSB = SPIGet(); // Get high 8 bits
RawTemp.byte.LSB = SPIGet(); // Get low 5 bits + "Bit 2" + 2
don't care bits (LSb side)
TC77_CS = 1; // Unselect TC77
// Restore interrupts.
GIEH = GIEHsave;
if ((RawTemp.uVal == 0x0000) || (RawTemp.uVal == 0xFFFF))
strcpypgm2ram( buffer, (rom char *)"Problem reading TC77." );
else
// Right align the 13 bit temperature reading
RawTemp.uVal >>= 3;
// Sign extend the value from 13 bits to 16 bits
if(((BYTE_VAL*)&RawTemp.byte.MSB)->bits.b4)
RawTemp.byte.MSB |= 0xE0;
// Convert the TC77 integer to a scaled one with units 0.0001
degrees C
ScaledTemp = (long)RawTemp.Val * (long)625;
// Convert the integer to a string and find its length
pTempString = ltoa( ScaledTemp, tempString );
strLen = strlen( tempString );
// Write the negative sign if needed. We are going to
// format small negative numbers a little differently.
ptr = buffer;
if(tempString[0] == '-')
*ptr++ = '-';
strLen--;
pTempString++;
// Write "0." and then the number if this number is too close
to zero; eg: 0, 0.0625, -0.125
if(strLen < 5)
*ptr++ = '0';
*ptr++ = '.';
memcpy( (void *)ptr, (void *)tempString, strLen );
*ptr += strLen;
// Otherwise, write the full number and write
// the decimal place in digit 5's position;
// eg: 24.1250
else
for(;strLen >= 5; strLen--)
*ptr++ = *pTempString++;
*ptr++ = '.';
for(;strLen > 0; strLen--)
// Write °C"
*ptr++ = ' ';
*ptr++ = 'C';
*ptr = '\0';
return strlen( buffer );
Meine Frage: Wie baue ich die Funktion in das Programm ein? Also wie
rufe ich diese Funktion auf? Ich muss doch einen Wert in die Funktion
geben (char *buffer), ich weiss aber nicht wie das aussehen soll. Ich
bin erst am Anfang bezüglich meiner Programmierfähigkeiten.
Ich hoffe ihr könnt mir helfen. Ich bedanke mich schonmal im vorraus.
