1 | AT91PS_SPI pSPI = AT91C_BASE_SPI;
2 | AT91PS_PIO pPIOA = AT91C_BASE_PIOA;
3 | AT91PS_PMC pPMC = AT91C_BASE_PMC;
4 | // not used: AT91PS_PDC pPDC_SPI = AT91C_BASE_PDC_SPI;
5 |
6 | // disable PIO from controlling MOSI, MISO, SCK (=hand over to SPI)
7 | // keep CS untouched - used as GPIO pin during init
8 | pPIOA->PIO_PDR = AT91C_PA12_MISO | AT91C_PA13_MOSI | AT91C_PA14_SPCK; // | NCPS_PDR_BIT;
9 | // set pin-functions in PIO Controller
10 | pPIOA->PIO_ASR = AT91C_PA12_MISO | AT91C_PA13_MOSI | AT91C_PA14_SPCK; /// not here: | NCPS_ASR_BIT;
11 | /// not here: pPIOA->PIO_BSR = NPCS_BSR_BIT;
12 |
13 | // set chip-select as output high (unselect card)
14 | pPIOA->PIO_PER = NCPS_PDR_BIT; // enable GPIO of CS-pin
15 | pPIOA->PIO_SODR = NCPS_PDR_BIT; // set high
16 | pPIOA->PIO_OER = NCPS_PDR_BIT; // output enable
17 |
18 | // enable peripheral clock for SPI ( PID Bit 5 )
19 | pPMC->PMC_PCER = ( (euint32) 1 << AT91C_ID_SPI ); // n.b. IDs are just bit-numbers
20 |
21 | // SPI enable and reset
22 | pSPI->SPI_CR = AT91C_SPI_SPIEN | AT91C_SPI_SWRST;
23 |
24 | #ifdef FIXED_PERIPH
25 | // SPI mode: master, fixed periph. sel., FDIV=0, fault detection disabled
26 | pSPI->SPI_MR = AT91C_SPI_MSTR | AT91C_SPI_PS_FIXED | AT91C_SPI_MODFDIS;
27 | // set PCS for fixed select
28 | // pSPI->SPI_MR &= 0xFFF0FFFF; // clear old PCS - redundant (AT91lib)
29 | pSPI->SPI_MR |= ( (SPI_MR_PCS<<16) & AT91C_SPI_PCS ); // set PCS
30 | #else
31 | // SPI mode: master, variable periph. sel., FDIV=0, fault detection disabled
32 | // Chip-Select-Decoder Mode (write state of CS-Lines in TDR)
33 | pSPI->SPI_MR = AT91C_SPI_MSTR | AT91C_SPI_MODFDIS | AT91C_SPI_PCSDEC ;
34 | #endif
35 |
36 | // set chip-select-register
37 | // 8 bits per transfer, CPOL=1, ClockPhase=0, DLYBCT = 0
38 | // TODO: Why has CPOL to be active here and non-active on LPC2000?
39 | // Take closer look on timing diagrams in datasheets.
40 | // not working pSPI->SPI_CSR[SPI_CSR_NUM] = AT91C_SPI_CPOL | AT91C_SPI_BITS_8 | AT91C_SPI_NCPHA;
41 | // not working pSPI->SPI_CSR[SPI_CSR_NUM] = AT91C_SPI_BITS_8 | AT91C_SPI_NCPHA;
42 | pSPI->SPI_CSR[SPI_CSR_NUM] = AT91C_SPI_CPOL | AT91C_SPI_BITS_8;
43 | // not working pSPI->SPI_CSR[SPI_CSR_NUM] = AT91C_SPI_BITS_8;
44 |
45 | // slow during init
46 | if_spiSetSpeed(0xFE);
47 |
48 | // enable
49 | pSPI->SPI_CR = AT91C_SPI_SPIEN;
50 |
51 | /* Send 20 spi commands with card not selected */
52 | for(i=0;i<21;i++) {
53 | if_spiSend(iface,0xFF);
54 | }
55 |
56 | /* enable automatic chip-select */
57 | // reset PIO-registers of CS-pin to default
58 | pPIOA->PIO_ODR = NCPS_PDR_BIT; // input
59 | pPIOA->PIO_CODR = NCPS_PDR_BIT; // clear
60 | // disable PIO from controlling the CS pin (=hand over to SPI)
61 | pPIOA->PIO_PDR = NCPS_PDR_BIT;
62 | // set pin-functions in PIO Controller (function NCPS for CS-pin)
63 | pPIOA->PIO_ASR = NCPS_ASR_BIT;
64 | pPIOA->PIO_BSR = NPCS_BSR_BIT;
