bootloader doesn't start
Gast #1890000
Hello,
I tried to use the SDK example bootloader, unfortunately I haven’t had
success.
The problem is that the bootloader doesn’t start working. It never
reaches the main method. To get around this problem I tried several
changes in the code. So I figured out, that the program works if I
delete a few lines of code. I deleted a few print lines and the program
seems to work.
I downloaded the bootloader to the FPGA and it starts workin. But when I
program the flash memory with the srec file, the bootloader doesn’t
react anymore. At least I think so, because the only why to figure it
out is a print() command at the beginning of the main method.
I’m using a ML605 Board.
Has anyone a suggestion?
  • [vhdl]VHDL-Code[/vhdl]
