1 | #include <pic.h>
2 | #include <stdlib.h>
3 | #include <stdio.h>
4 |
5 | /* PIC Configuration Bit:
6 | ** INTIO - Using Internal RC No Clock
7 | ** WDTDIS - Wacthdog Timer Disable
8 | ** PWRTEN - Power Up Timer Enable
9 | ** MCLREN - Master Clear Enable
10 | ** UNPROTECT - Code Un-Protect
11 | ** UNPROTECT - Data EEPROM Read Un-Protect
12 | ** BORDIS - Borwn Out Detect Disable
13 | ** IESODIS - Internal External Switch Over Mode Disable
14 | ** FCMDIS - Monitor Clock Fail Safe Disable
15 | */
16 | __CONFIG(INTIO & WDTDIS & PWRTEN & MCLREN & UNPROTECT \
17 | & UNPROTECT & BORDIS & IESODIS & FCMDIS);
18 |
19 | // Using Internal Clock of 8 MHz
20 | #define FOSC 8000000L
21 | #define BAUD_RATE 9600
22 |
23 |
24 | // Delay Function
25 | #define _delay_us(x) { unsigned char us; \
26 | us = (x)/(12000000/FOSC)|1; \
27 | while(--us != 0) continue; }
28 |
29 | void _delay_ms(unsigned int ms)
30 | {
31 | unsigned char i;
32 | do {
33 | i = 4;
34 | do {
35 | _delay_us(164);
36 | } while(--i);
37 | } while(--ms);
38 | }
39 |
40 | // BRAM UART Debugging Function
41 |
42 | void ansi_cl(void)
43 | {
44 | // ANSI clear screen: cl=\E[H\E[J
45 | putchar(27);
46 | putchar('[');
47 | putchar('H');
48 | putchar(27);
49 | putchar('[');
50 | putchar('J');
51 | }
52 |
53 | void ansi_me(void)
54 | {
55 | // ANSI turn off all attribute: me=\E[0m
56 | putchar(27);
57 | putchar('[');
58 | putchar('0');
59 | putchar('m');
60 | }
61 |
62 | void uart_init(void)
63 | {
64 | TRISB5 = 1; // Set Port B5 and B7 for UART Tx and Rx
65 | TRISB7 = 0;
66 |
67 | // Baud Rate formula for SYNC=0 (Async), BRG16=0 (8-bit), BRGH=0 (low speed)
68 | // 0.16% Error for 8 MHz Oscilator Clock. Actual Rate will be 9615.
69 | // BAUD_RATE = FOSC / (64 x (SPBRG + 1))
70 |
71 | SPBRG = (int)(FOSC/(64UL * BAUD_RATE) - 1);
72 | TXSTA = 0b00100000; // Async, 8 bit and Enable Transmit (TXEN=1)
73 | RCSTA = 0b10010000; // Serial Port Enable, Async,8-bit and Enable Receipt (CREN=1)
74 | BAUDCTL=0;
75 | }
76 |
77 | void putch(unsigned char data)
78 | {
79 | // Send Data when TXIF bit is ready
80 | while(!TXIF) continue;
81 | TXREG = data;
82 | }
83 |
84 | unsigned char getch(void) {
85 | // Get Data when RCIF bit is ready
86 | while(!RCIF) continue;
87 | return RCREG;
88 | }
89 |
90 | void main(void)
91 | {
92 | ansi_me();
93 | ansi_cl();
94 |
95 | while (1)
96 | {
97 | OSCCON=0x70; // Select 8 MHz internal clock
98 |
99 | TRISA = 0x03; // Input for RA0 and RA1
100 | TRISC = 0x07; // Set RC0,RC1 and RC2 as input others as Output
101 | ANSEL = 0x71; // Set PORT AN0, AN4, AN5 and AN6 as analog input
102 | ANSELH = 0x00; // Set PORT AN8 to AN11 as Digital I/O
103 | PORTC = 0x00; // Turn Off all PORTC
104 | // Initial PIC16F690 UART
105 | uart_init();
106 |
107 | // Set the Attribute and Clear Screen
108 |
109 | printf("Welcome");
110 | putch("a");
111 | }
112 | }
