Hallo Leute, ich versuche einen MOSFET irl3714 im LTSpice anzulegen. Habe das Model von der IR Seite runtergeladen und in einem Texteditor komplet als irl3714z_s_l.lib gespeichert. Hier ist das Model _______________________________________________________________ .SUBCKT irl3714z_s_l 1 2 3 * SPICE3 MODEL WITH THERMAL RC NETWORK ************************************** Model Generated by MODPEX *Copyright(c) Symmetry Design Systems* All Rights Reserved UNPUBLISHED LICENSED SOFTWARE Contains Proprietary Information Which is The Property of SYMMETRY OR ITS LICENSORS Commercial Use or Resale Restricted by Symmetry License Agreement ************************************** * Model generated on Jun 22, 04 * MODEL FORMAT: SPICE3 * Symmetry POWER MOS Model (Version 1.0) * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=100u W=100u .MODEL MM NMOS LEVEL=1 IS=1e-32 +VTO=2.63853 LAMBDA=0 KP=45.4893 +CGSO=4.45235e-06 CGDO=1.1492e-07 RS 8 3 0.0103197 D1 3 1 MD .MODEL MD D IS=2.70143e-12 RS=0.00721606 N=1.04861 BV=20 +IBV=0.00025 EG=1.2 XTI=2.96785 TT=1.00001e-07 +CJO=2.76532e-10 VJ=0.5 M=0.409124 FC=0.5 RDS 3 1 1e+06 RD 9 1 0.0001 RG 2 7 2.18034 D2 4 5 MD1 * Default values used in MD1: * RS=0 EG=1.11 XTI=3.0 TT=0 * BV=infinite IBV=1mA .MODEL MD1 D IS=1e-32 N=50 +CJO=1.2665e-10 VJ=4.66779 M=0.3 FC=1e-08 D3 0 5 MD2 * Default values used in MD2: * EG=1.11 XTI=3.0 TT=0 CJO=0 * BV=infinite IBV=1mA .MODEL MD2 D IS=1e-10 N=0.439082 RS=3e-06 RL 5 10 1 FI2 7 9 VFI2 -1 VFI2 4 0 0 EV16 10 0 9 7 1 CAP 11 10 4.35626e-10 FI1 7 9 VFI1 -1 VFI1 11 6 0 RCAP 6 10 1 D4 0 6 MD3 * Default values used in MD3: * EG=1.11 XTI=3.0 TT=0 CJO=0 * RS=0 BV=infinite IBV=1mA .MODEL MD3 D IS=1e-10 N=0.439082 .ENDS irl3714z_s_l *SPICE Thermal Model Subcircuit .SUBCKT irl3714z_s_lt 3 0 R_RTHERM1 3 2 1.291698867 R_RTHERM2 2 1 2.336748834 R_RTHERM3 1 0 0.651552298 C_CTHERM1 3 0 0.000104514 C_CTHERM2 2 0 0.000377447 C_CTHERM3 1 0 0.008398405 .ENDS irl3714z_s_lt __________________________________________ Dann habe ich das mit einem Symbol aus der Bibliothek (NMOS) verbunden und gespeichert als irl3714.asy. Sobald ich das Model simulieren will, spuckt LTSpice aus, dass er diesen Bibliothekfile nicht öffnen kann. Kann mir jemand bitte helfen. Brauche das dringend. Danke
Hallo Peter, wir haben hier den Mosfet als Subcircuit .SUBCKT irl3714z_s_l 1 2 3 Damit brauchen wir auch ein Symbol für ein Subcircuit im Schaltplan. Man braucht aber nicht extra eines machen in diese Fall. Profis machen das so: 1. "nmos" auf den Schaltplan 2. An dem platzierten nmos das wort nmos durch irl3714z_s_l ersetzen. Du darfst es auch groß schreiben wenn du willst, IRL3714Z_S_L. 3. Ctrl-rechte-Maustaste auf das platzierte Bauteil. Jetzt kommt ein Dialogfenster mit allen Attributen. Im Prefix X reinschreiben, damit der Netzlistengenerator weiß, dass das Bauteil ein Subcircuit ist. Prefix:X OK 4. LTspice noch mitteilen, wo der File mit dem Modell liegt. Dazu eine SPICE-Directive in den Schaltplan legen. .include filename Den File in das Verzeichnis des Schaltplans legen. Fertig Gruß Helmut User group: http://tech.groups.yahoo.com/group/LTspice/
