Hi, Ein Nominal-bit-time besteht aus Sync-segment, Propagation-delay-segment, Phase-buffer-segment1 und Phase-buffer-segment2, wobei Sample-point zw. Phase-buffer-segment1 und Phase-buffer-segment2 ist. Die Beschreibung lautet: The CAN protocol regulates bus access by bit-wise arbitration. The signal propagation from sender to receiver and back to the sender must be completed within one bit-time. For synchronization purposes a further time segment, the propagation delay segment, is needed in addition to the time reserved for synchronization, the phase buffer segments. The propagation delay segment takes into account the signal propagation on the bus as well as signal delays caused by transmitting and receiving nodes. Was versteht man unter Nominal-bit-time? MfG Hauser
