1 | #include "main.h"
2 | #define an(port,b) (port) |= (1<<(b))
3 | #define aus(port,b) (port) &= ~(1<<(b))
4 |
5 | #define RC5TIME 1.778e-3 // 1.778msec
6 | #define PULSE_MIN (uchar)(XTAL / 512 * RC5TIME * 0.4 + 0.5)
7 | #define PULSE_1_2 (uchar)(XTAL / 512 * RC5TIME * 0.8 + 0.5)
8 | #define PULSE_MAX (uchar)(XTAL / 512 * RC5TIME * 1.2 + 0.5)
9 |
10 |
11 | uchar rc5_bit; // bit value
12 | uchar rc5_time; // count bit time
13 | uint rc5_tmp; // shift bits in
14 | uint rc5_data; // store result
15 |
16 |
17 | SIGNAL (SIG_OVERFLOW0)
18 | {
19 | uint tmp = rc5_tmp; // for faster access
20 |
21 | TCNT0 = -2; // 2 * 256 = 512 cycle
22 |
23 | if( ++rc5_time > PULSE_MAX ){ // count pulse time
24 | if( !(tmp & 0x4000) && tmp & 0x2000 ) // only if 14 bits received
25 | rc5_data = tmp;
26 | tmp = 0;
27 | }
28 |
29 | if( (rc5_bit ^ xRC5_IN) & 1<<xRC5 ){ // change detect
30 | rc5_bit = ~rc5_bit; // 0x00 -> 0xFF -> 0x00
31 |
32 | if( rc5_time < PULSE_MIN ) // to short
33 | tmp = 0;
34 |
35 | if( !tmp || rc5_time > PULSE_1_2 ){ // start or long pulse time
36 | if( !(tmp & 0x4000) ) // not to many bits
37 | tmp <<= 1; // shift
38 | if( !(rc5_bit & 1<<xRC5) ) // inverted bit
39 | tmp |= 1; // insert new bit
40 | rc5_time = 0; // count next pulse time
41 | }
42 | }
43 |
44 | rc5_tmp = tmp;
45 | }
46 |
47 |
48 | void putchar( char c )
49 | {
50 | while( (UCSRA & 1<<UDRE) == 0 );
51 | UDR = c;
52 | }
53 |
54 |
55 | void puts( char *s )
56 | {
57 | while( *s )
58 | putchar( *s++ );
59 | }
60 |
61 |
62 | int main( void )
63 | {
64 | DDRB = 0xFF; //Port B als Ausgang
65 | DDRD = 0x7F; //PD7 Eingang
66 | uint i;
67 | char s[30];
68 |
69 | TCCR0 = 1<<CS02; //divide by 256
70 | TIMSK = 1<<TOIE0; //enable timer interrupt
71 |
72 | UBRRL = bauddivider; //set baud rate
73 | UBRRH = bauddivider >> 8;
74 | UCSRA = 0; //no U2X, MPCM
75 | UCSRC = 1<<URSEL^1<<UCSZ1^1<<UCSZ0; //8 Bit
76 | UCSRB = 1<<RXEN^1<<TXEN; //enable RX, TX
77 |
78 | sei();
79 | puts( "RC5-Dekoder:\n\r" );
80 | for(;;){ // main loop
81 | cli();
82 | i = rc5_data; // read two bytes from interrupt !
83 | rc5_data = 0;
84 | sei();
85 | if( i ){
86 | DDRB = i; // LED output
87 | putchar(( i >> 11 & 1) + '0'); // Toggle Bit
88 | putchar(' ');
89 | itoa( i >> 6 & 0x1F, s, 10); // Device address
90 | puts( s );
91 | putchar(' ');
92 | itoa((i & 0x3F) | (~i >> 7 & 0x40), s, 10); // Key Code
93 | puts( s );
94 | puts( "\n\r" );
95 | }
96 | }
97 | }
