Hallo, ich habe hier diesen Beispiel Code von Atmel. Habe versucht ihn zu verstehen, bin aber noch sehr unerfahren und komme nicht weiter. Kann mir hier einer helfen? Danke im Vorraus Gruß Denis #include "avr_compiler.h" #include "twi_master_driver.h" #include "twi_slave_driver.h" /*! Defining an example slave address. */ #define SLAVE_ADDRESS 0x55 /*! Defining number of bytes in buffer. */ #define NUM_BYTES 8 /*! CPU speed 2MHz, BAUDRATE 100kHz and Baudrate Register Settings */ #define CPU_SPEED 2000000 #define BAUDRATE 100000 #define TWI_BAUDSETTING TWI_BAUD(CPU_SPEED, BAUDRATE) /* Global variables */ TWI_Master_t twiMaster; /*!< TWI master module. */ TWI_Slave_t twiSlave; /*!< TWI slave module. */ /*! Buffer with test data to send.*/ uint8_t sendBuffer[NUM_BYTES] = {0x55, 0xAA, 0xF0, 0x0F, 0xB0, 0x0B, 0xDE, 0xAD}; /*! Simple function that invert the received value in the sendbuffer. This * function is used in the driver and passed on as a pointer to the driver. */ void TWIC_SlaveProcessData(void) { uint8_t bufIndex = twiSlave.bytesReceived; twiSlave.sendData[bufIndex] = (~twiSlave.receivedData[bufIndex]); } /*! /brief Example code * * Example code that reads the key pressed and show a value from the buffer, * sends the value to the slave and read back the processed value which will * be inverted and displayed after key release. */ int main(void) { /* Initialize PORTE for output and PORTD for inverted input. */ PORTE.DIRSET = 0xFF; PORTD.DIRCLR = 0xFF; PORTCFG.MPCMASK = 0xFF; PORTD.PIN0CTRL |= PORT_INVEN_bm; // PORTCFG.MPCMASK = 0xFF; // PORTD.PIN0CTRL = (PORTD.PIN0CTRL & ~PORT_OPC_gm) | PORT_OPC_PULLUP_gc; //Enable internal pull-up on PC0, PC1.. Uncomment if you don't have external pullups PORTCFG.MPCMASK = 0x03; // Configure several PINxCTRL registers at the same time PORTC.PIN0CTRL = (PORTC.PIN0CTRL & ~PORT_OPC_gm) | PORT_OPC_PULLUP_gc; //Enable pull-up to get a defined level on the switches /* Initialize TWI master. */ TWI_MasterInit(&twiMaster, &TWIC, TWI_MASTER_INTLVL_LO_gc, TWI_BAUDSETTING); /* Initialize TWI slave. */ TWI_SlaveInitializeDriver(&twiSlave, &TWIC, TWIC_SlaveProcessData); TWI_SlaveInitializeModule(&twiSlave, SLAVE_ADDRESS, TWI_SLAVE_INTLVL_LO_gc); /* Enable LO interrupt level. */ PMIC.CTRL |= PMIC_LOLVLEN_bm; sei(); uint8_t BufPos = 0; while (1) { while(!PORTD.IN); /* Wait for user to press button */ switch(PORTD.IN){ case (PIN0_bm): BufPos = 0; break; case (PIN1_bm): BufPos = 1; break; case (PIN2_bm): BufPos = 2; break; case (PIN3_bm): BufPos = 3; break; case (PIN4_bm): BufPos = 4; break; case (PIN5_bm): BufPos = 5; break; case (PIN6_bm): BufPos = 6; break; case (PIN7_bm): BufPos = 7; break; default: break; } /* Show the byte to send while holding down the key. */ while(PORTD.IN != 0x00){ PORTE.OUT = sendBuffer[BufPos]; } TWI_MasterWriteRead(&twiMaster, SLAVE_ADDRESS, &sendBuffer[BufPos], 1, 1); while (twiMaster.status != TWIM_STATUS_READY) { /* Wait until transaction is complete. */ } /* Show the sent byte received and processed on LEDs. */ PORTE.OUT = (twiMaster.readData[0]); while(PORTD.IN); /* Wait for user to release button */ } } /*! TWIC Master Interrupt vector. */ ISR(TWIC_TWIM_vect) { TWI_MasterInterruptHandler(&twiMaster); } /*! TWIC Slave Interrupt vector. */ ISR(TWIC_TWIS_vect) { TWI_SlaveInterruptHandler(&twiSlave); }
Die XMEGA-Firmware-Library ist dokumentiert. In der Doku müssen wohl alle, die die Library verwenden wollen (früher oder später) mal drin schmökern. Das Datenblatt des verwendeten Controllers ist da unter Umständen auch ganz hilfreich. Gruß Oliver
Hallo, ja Danke für die Antwort. Ich habe mich natührlich mit der Dokumentation auseinander gesetzt. Habe trotzdem ein Problem! Wenn ich zum Beispiel für Slave folgendes parametriere: #define SLAVE_ADDRESS 0xA0 Dieses Byte soll der Master als erstes an den Slave eigentlich rausschicken, jedoch kippt er es aus irgend einem grund um und schickt 0x40 raus und ich verstehe nicht warum!!!! Kann mir da jemand helfen? Dieser Beispielcode ist von der Atmelseite für AtXmega128A1: http://www.atmel.com/dyn/resources/prod_documents/AVR1308.zip
TWI_SlaveInitializeModule() scheint sein drittes Argument als TWI-Adresse im 7-bit Format anzusehen und shiftet die Adresse für das anzuhängende LSB Bit R/W eins nach links. Siehe z.B. http://www.mikrocontroller.net/attachment/125829/twi_bus.c
1 | twi->interface->SLAVE.ADDR = (address << 1) | (general_call << 0);//(1<<0) gerneral call enable/disable |
Wenn du wirklich 0xA0 als SLAVE ADDRESS benutzen willst, musst du (0xA0>>1) übergeben.
Danke versuche ich heute Abend zu realisieren!!
Hallo, habe es ausprobiert und es funktioniert. Danke Habe jetzt aber zwei weitere Probleme und zwar: 1) wenn ich z.B. ein Feld definiere uint8_t sendBuffer[2] = {0x55, 0xAA}; und dieser Funktion übergebe TWI_MasterWriteRead(&twiMaster, SLAVE_ADDRESS, &sendBuffer[BufPos], 2, 2); sendet der Master erst mal die Slave Adresse dann die beiden Bytes aus dem Feld und soll dann zwei Bytes vom Slave auslesen jedoch liest er nur ein Byte aus. Muss ich den ersten Byte (speziell) erstmal aus dem Register abholen, damit er den zweiten auslesen kann?? 2) Ich wollte ja eigentlich mit Hilfe von TWI ein EEPROM auslesen und beschreiben. Wenn ich zum Beispiel mehrere Bytes(oder auch eins) hintereinander auslese, muss ich beim letzten Byte NO ACK setzen (siehe diesen Link Seite 12: http://www.atmel.com/dyn/resources/prod_documents/doc0670.pdf ). Wo kann ich es bei Atmel Quellcode setzen??? Vielen Dank im Voraus!!!!! Denis
dann schnapp dir die vorhandene lib und bau dir daraus ne eigene schreib/lesefunktion die so arbeitet wie gewünscht
das ist bereits in deinem Befehl TWI_MasterWriteRead... implmementiert
Da musst du garnichts machen. Nur die Befehle Startadressen usw. richtig
behandeln.
Bei meinem Beispiel ist der Schreib- und Lesebefehl getrennt.
siehe Beispiel:
void mcp3421_eingabe(void) // schreiben Befehl
uint8_t buffer[1];
buffer[0]= 0x88; // Startadresse
TWI_MasterWriteRead(&twiMaster,SLAVE_ADDRESS,buffer,1,0);
while (twiMaster.status != TWIM_STATUS_READY) {}
void mcp3421_auslesen(TWI_Master_t *twi) // auslesen Daten
TWI_MasterWriteRead(&twiMaster,SLAVE_ADDRESS,0,0,3);
h_byte = twi->readData[0x00];
l_byte = twi->readData[0x01];
conf_reg = twi->readData[0x02];
Gruß xmega
