Hello everybody, I have got no idea what is wrong with the following code: All I want to do, is to set a Pin on "input-Mode" with a PullUp, but if I measure the voltage at the Pin, all I get is between 0.4V and 0.5V. I had expected a Value about ~3.2 V, and so the Interrupt Routine doesn't start either. Do I somehow have destroyed the entrance, or could the mistake be solved within the code? The code is below after the german version of the question: _____________________ Hallo allerseits, bin gerade etwas ratlos. Ich dachte, ich hätte mit meinem Code einen Pin auf Eingang gesetzt und den Pulluip aktiviert. Nachmessen zeigt allerdings, dass nur 0,4 bis 0,5 Volt anliegen. Hab ich den Eingang irgendwie zerschossen, oder liegt es nur an dem Code? _____________________________ CMU_ClockEnable(cmuClock_GPIO, true); //GPIO mit Clock verdrahten GPIO_PinModeSet(gpioPortC, 14, gpioModeInputPull, 1); //Input with PullUp GPIO_IntConfig(gpioPortC, 14, false, true, true); NVIC_ClearPendingIRQ(GPIO_EVEN_IRQn); NVIC_EnableIRQ(GPIO_EVEN_IRQn); thanks to everyone allen ein Dankeschön
is "GPIO_IntConfig" some kind of PinChange-Interrupt? ___________________________________________________ ist "GPIO_IntConfig" sowas wie ein PinChange-Interrupt?
yes it is.
thank all of you for reading this. Sometimes the error is too simple.
I have measured the impedance between the neigbhoured pins and found out
that it was much too small.
So I took a cotton stick and some acetone and cleaned it up. Now I get
the desirerd high voltage level of 3.3V...
...but now another error occurs and this is not a hardwareproblem, it
has to do with the interrupts.
void SysTick_Handler(void)
msTicks++; /* incr counter used in Delay()*/
void GPIO_EVEN_IRQHandler(void)
GPIO_IntClear(1 << 14);
void Delay(uint32_t dlyTicks)
uint32_t curTicks;
curTicks = msTicks;
while ((msTicks - curTicks) < dlyTicks) ;
// Taster Pin PC14 set to Input Falling Edge
void Taster_config(void)
GPIO_PinModeSet(gpioPortC, 14, gpioModeInputPullFilter, 1);
int main(void)
CHIP_Init();
SystemCoreClockUpdate();
if (SysTick_Config(SystemCoreClock / 1000)) while (1) ;
//Clock connect with GPIO Module
//Benutzer_LED als Push-Pull-Drive mit 0.5 mA einstellen
GPIO_DriveModeSet(gpioPortA, gpioDriveModeLowest); //0.5 mA
GPIO_PinModeSet(gpioPortA, 1, gpioModePushPullDrive , 0);
Taster_config();
while(1)
Delay(500);
GPIO_PinOutToggle(gpioPortA, 1);
}//end while(1)
}//end main
So... the programm lights up the LED in 0.5sec and another 0.5 sec. it
is dark.
Then the programm hang up, wehn the Button PC14 is pressed...
What can I do against this?
Thanks in advance!
Hi The code seems fine, but I suspect your project settings might be set up for the wrong device. If your project includes the startup file for a Gecko micro, the interrupt vectors will not match a Tiny Gecko for instance. This could cause the kind of error you are experiencing. There are some guidelines on how to port a project here: http://support.energymicro.com/entries/20287387-port-iar-project-from-gecko-to-tiny-gecko Christian
You can also try to debug this. When I experience hangs, I just pause the program in the debugger, and look what the EFM32 is doing right now - with the stack trace I usually see where the culprit lies. (I'm using the IAR toolchain)
