1 | unsigned char MMC_FLASH_Clear (unsigned long address, unsigned char *scratch,
2 | unsigned int length)
3 | {
4 | idata unsigned long flash_page_1; // Stores address of first FLASH page;
5 | idata unsigned long flash_page_2; // Stores address of second FLASH page;
6 | idata unsigned int card_status; // Stores MMC status after each MMC
7 | // command;
8 | idata unsigned int counter; // Counter for clearing bytes in local
9 | // block copy;
10 | unsigned char xdata *index; // Index into local block used for
11 | // clearing desired data;
12 | if(length > 512) return 0; // Test desired clear length; If
13 | // length > 512, break out and return
14 | // zero;
15 | // Calculate first FLASH page address;
16 | flash_page_1 = address & ~(PHYSICAL_BLOCK_SIZE-1);
17 | // Calculate second FLASH page address;
18 | flash_page_2 = (address+length-1) & ~(PHYSICAL_BLOCK_SIZE-1);
19 | if(flash_page_1 == flash_page_2) // Clear space all in one FLASH block
20 | { // condition;
21 | // Read first FLASH block;
22 | card_status = MMC_Command_Exec(SET_BLOCKLEN,
23 | (unsigned long)PHYSICAL_BLOCK_SIZE,
24 | EMPTY);
25 | card_status = MMC_Command_Exec(READ_SINGLE_BLOCK,flash_page_1,scratch);
26 | // Set index to address of area to clear
27 | // in local block;
28 | @@ index = (unsigned int)(address % PHYSICAL_BLOCK_SIZE) + scratch;
29 | counter = 0;
30 | while(counter<length) // Clear desired area in local block;
31 | {
32 | *index++ = 0x00;
33 | counter++;
34 | }
35 | // Tag first FLASH page for erase;
36 | card_status = MMC_Command_Exec(TAG_SECTOR_START,flash_page_1,EMPTY);
37 | card_status = MMC_Command_Exec(TAG_SECTOR_END,flash_page_1,EMPTY);
38 | // Erase first FLASH page;
39 | card_status = MMC_Command_Exec(ERASE,EMPTY,EMPTY);
40 | // Write local copy of block back out
41 | // to MMC;
42 | card_status = MMC_Command_Exec(WRITE_BLOCK,flash_page_1,scratch);
43 | }
44 | else // Clear space crosses FLASH block
45 | { // boundaries condition;
46 | // Follow same procedure as for single
47 | // block case above; Read first block
48 | // clear data from start address to end
49 | // of block; Erase block in FLASH;
50 | // Write local copy back out;
51 | card_status = MMC_Command_Exec(SET_BLOCKLEN,
52 | (unsigned long)PHYSICAL_BLOCK_SIZE,
53 | EMPTY);
54 | card_status = MMC_Command_Exec(READ_SINGLE_BLOCK,flash_page_1,scratch);
55 | @@ index = (unsigned int)(address % PHYSICAL_BLOCK_SIZE) + scratch;
56 | counter = (unsigned int)(flash_page_2 - address);
57 | while(counter > 0)
58 | {
59 | *index++ = 0xFF;
60 | counter--;
61 | }
62 | card_status = MMC_Command_Exec(TAG_SECTOR_END,flash_page_1,EMPTY);
63 | card_status = MMC_Command_Exec(ERASE,EMPTY,EMPTY);
64 | card_status = MMC_Command_Exec(WRITE_BLOCK,flash_page_1,scratch);
65 | // Same process as above, but using
66 | // second FLASH block; Area to be
67 | // cleared extends from beginning of
68 | // second FLASH block to end of desired
69 | // clear area;
70 | card_status = MMC_Command_Exec(READ_SINGLE_BLOCK,flash_page_2,scratch);
71 | @@ index = scratch;
72 | counter = (unsigned int)(length - (flash_page_2 - address));
73 | while(counter > 0)
74 | {
75 | *index++ = 0xFF;
76 | counter--;
77 | }
78 | card_status = MMC_Command_Exec(TAG_SECTOR_END,flash_page_2,EMPTY);
79 | card_status = MMC_Command_Exec(ERASE,EMPTY,EMPTY);
80 | card_status = MMC_Command_Exec(WRITE_BLOCK,flash_page_2,scratch);
81 | }
82 | }
