1 | /******************************************************************************/
2 | /* Files to Include */
3 | /******************************************************************************/
4 |
5 | #include <p30F4011.h> /* Device header file */
6 | #include <stdint.h> /* For uint32_t definition */
7 | #include <stdbool.h> /* For true/false definition */
8 | #include <libpic30.h>
9 | /* variables/params used by user.c */
10 |
11 | /******************************************************************************/
12 | /* User Functions */
13 | /******************************************************************************/
14 |
15 | /* <Initialize variables in user.h and insert code for user algorithms.> */
16 |
17 | /* TODO Initialize User Ports/Peripherals/Project here */
18 |
19 | void InitApp(void)
20 | {
21 | /* Setup analog functionality and port direction */
22 | /*Port B Init*/
23 | LATB = 0;
24 | TRISB = 0b111000000;
25 | /* Configure AN6 as analog inputs*/
26 | ADPCFG = 0xFFBF; // PORTB pins AN6 is analog input
27 | ADCON1 = 0x0000; // Manually clear SAMP to end sampling, start conversion
28 | ADCON2 = 0x0100; // Voltage reference from AVDD and AVSS
29 | ADCON3 = 0x0005; // Manual Sample, ADCS=5 -> Tad = 3*Tcy
30 | /*Configure PWM for free running mode
31 | PWM period = Tcy * prescale * PTPER = 0.33ns * 64 * PTPER
32 | PWM pulse width = (Tcy/2) * prescale * PDC*/
33 |
34 | PWMCON1 = 0x00FF; // Enable all PWM pairs in complementary mode
35 | PTCON = 0;
36 | _PTCKPS = 3; // prescale=1:64 (0=1:1, 1=1:4, 2=1:16, 3=1:64)
37 | PTPER = 9470; // 20ms PWM period (15-bit period value)
38 | PDC1 = PTPER; // 50% duty cycle on PWM channel 1
39 | PDC2 = PTPER; // 50% duty cycle on PWM channel 2
40 | PDC3 = PTPER; // 50% duty cycle on PWM channel 3
41 | _PTEN = 1; // Enable PWM time base
42 | /*Configure Timer 1
43 | In this example, I'm setting PR1 and TCKPS for 8Hz*/
44 | T1CON = 0; // Clear the Timer 1 configuration
45 | TMR1 = 0; // Reset Timer 1 counter
46 | PR1 = 14648; // Set the Timer 1 period (max 65535)
47 | T1CONbits.TCS = 0; // Select internal clock (Fosc/4)
48 | T1CONbits.TCKPS = 3; // Prescaler (0=1:1, 1=1:8, 2=1:64, 3=1:256)
49 | _T1IP = 1; // Set the Timer 1 interrupt priority
50 | _T1IF = 0; // Clear the Timer 1 interrupt flag
51 | _T1IE = 1; // Enable Timer 1 interrupt
52 | T1CONbits.TON = 1; // Turn on Timer 1
53 | /*LCD Init*/
54 |
55 | __delay32(6000);
56 | LATBbits.LATB0=1;
57 | void BIT_Send(Init_4Bit);
58 | __delay32(3500);
59 | void BIT_Send(Init_4BitEN);
60 | __delay32(3500);
61 | void BIT_Send(Init_4Bit);
62 | __delay32(3500);
63 | void BIT_Send(Init_4BitEN);
64 | __delay32(3500);
65 | void BIT_Send(Init_Line);
66 | __delay32(3500);
67 | void BIT_Send(Init_LineEN);
68 | __delay32(3500);
69 | void BIT_Send(Init_Disp);
70 | __delay32(3500);
71 | void BIT_Send(Init_DispEN);
72 | __delay32(3500);
73 | void BIT_Send(Init_Cursor1);
74 | __delay32(3500);
75 | void BIT_Send(Init_Cursor1EN);
76 | __delay32(3500);
77 | void BIT_Send(Init_Disp);
78 | __delay32(3500);
79 | void BIT_Send(Init_DispEN);
80 | __delay32(3500);
81 | void BIT_Send(Init_Clear);
82 | __delay32(3500);
83 | void BIT_Send(Init_ClearEN);
84 | __delay32(3500);
85 | void BIT_Send(Init_Disp);
86 | __delay32(3500);
87 | void BIT_Send(Init_DispEN);
88 | __delay32(3500);
89 | void BIT_Send(Init_Line);
90 | __delay32(3500);
91 | void BIT_Send(Init_LineEN);
92 | __delay32(3500);
93 |
94 |
95 | /* Initialize peripherals */
96 | }
97 |
98 |
99 |
100 | /* This function reads a single sample from the specified
101 | analog input. It should take less than 2.5us if the chip
102 | is running at about 30 MIPS.
103 | Because the dsPIC30F4011 has a 10-bit ADC, the value
104 | returned will be between 0 and 1023.*/
105 | signed int read_analog_channel(int channel)
106 | {
107 |
108 | ADCHS = channel; // Select the requested channel
109 | ADCON1bits.ADON = 1; // Turn ADC ON
110 | ADCON1bits.SAMP = 1; // Start sampling
111 | __delay32(30); // 1us delay @ 30 MIPS
112 | ADCON1bits.SAMP = 0; // Start Converting
113 | while (!ADCON1bits.DONE);
114 | ADCON1bits.ADON = 0; // Turn ADC ON
115 | return ADCBUF0;
116 | }
117 | void Tick(void)
118 | {
119 | __delay32(30);
120 | LATBbits.LATB4 = 0;
121 | __delay32(30);
122 | LATBbits.LATB4 = 1;
123 | __delay32(30);
124 | LATBbits.LATB4 = 0;
125 | __delay32(30);
126 | }
127 | void Out_Tick(void)
128 | {
129 | __delay32(30);
130 | LATBbits.LATB5 = 0;
131 | __delay32(30);
132 | LATBbits.LATB5 = 1;
133 | __delay32(30);
134 | LATBbits.LATB5 = 0;
135 | __delay32(30);
136 | }
137 | void Send_Data(void)
138 | {
139 |
140 |
141 | }
142 | void BIT_Send(char Init[])
143 | {
144 |
145 | int i;
146 | for (i=0;i<9;i++)
147 | {
148 | LATBbits.LATB3 = Init[i];
149 | Tick();
150 | }
151 | Out_Tick();
152 | while(1);
153 | }
