Synchronous prbblem in VHDL
Gast #202343
i have a problem with this code... I obtain "Signal rstemp cannot be
synthesized, bad synchronous description."
thanks..
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity contatore is
port (
SET: in STD_LOGIC;
RESET: in STD_LOGIC;
RST: out STD_LOGIC;
LOAD, DIR: in STD_LOGIC;
DIN: in STD_LOGIC_VECTOR(3 downto 0);
TEST: out STD_LOGIC_VECTOR(3 downto 0));
end contatore;
architecture Behavioral of contatore is
SIGNAL next_state  : std_logic_vector (3 downto 0);
begin
process(SET, RESET, LOAD, DIN, DIR, next_state)
variable count  : std_logic_vector (3 downto 0);
variable Temp  : std_logic_vector (4 downto 0);
variable rstemp: STD_LOGIC;
begin
if (DIR='1') then
rstemp:='0';      -- conteggio up
case count is
  when "1001" => next_state<="0000";
  when others   => next_state<=count+1;
end case;
end if;
if (DIR='0') then      -- conteggio down
rstemp:='0';
case count is
  when "0000" => next_state<="1001";
  when others   => next_state<=count-1;
end case;
end if;
  if ((RESET and DIR)='1') then    --  Il reset ha priorità massima
    count:="0000";
  elsif (RESET='1' and DIR='0')  then
    count:="1001";
  elsif (Load='1') then        -- il load ha priorità secondaria
  count:=DIN;
  elsif (SET='1' and SET'event)  then   -- sensibile al fronte di
salita di SET
    count:=next_state;          -- conteggia
  end if;
TEST<=count;
Temp:= next_state & DIR;
     case Temp is
     when "00001" => rstemp:='1';
     when  "10010" => rstemp:='1';
     when  others  => rstemp:='0';
     end case;
  end if;
RST<=rstemp;
end process;
end Behavioral;
Gast #202348
Hello Daniele,
of course does it need a clock, even it is an asyc. counter!
The only difference between the code I wrote for you and this is, that
you renamed "clk" to "set" and insert "rstemp:='0'" in the
Lookup-tables.
You programmed, that rstemp should be "0" for both states of
"DIR".
This is opposite too:
     case Temp is
     end case;"
Look what "Temp" is: It is a combinition of "nextstate" and
"DIR".
The last bit of Temp is "DIR"!
So the error is that, what the compiler says: "bad describtion",
because nobody knows what you want (me too).
Henrik
