1 | #define TSIC_PORT PORTD // Port to use
2 | #define TSIC_PIN PIND
3 | #define TSIC_PORT_DDR DDRD
4 | #define TSCI_POWER_PIN PD6 // Where TSIC-Sensors VCC is connected
5 | #define TSIC_SIGNAL_PIN PD7 // Where TSIC-Sensors "Signal"-Pin is con.
6 |
7 |
8 | /******************************************************************************
9 | * FUNCTION MACROS
10 | ******************************************************************************/
11 |
12 | // Define TSCI_POWER_PIN as output, TSIC_SIGNAL_PIN as input
13 | #define TSIC_INIT() { TSIC_PORT_DDR |= (1<<TSCI_POWER_PIN); \
14 | TSIC_PORT_DDR &= ~(1<<TSIC_SIGNAL_PIN); }
15 |
16 | // Power up the TSIC-Sensor
17 | #define TSIC_ON() TSIC_PORT |= (1<<TSCI_POWER_PIN)
18 |
19 | // Power down the TSIC-Sensor
20 | #define TSIC_OFF() TSIC_PORT &= ~(1<<TSCI_POWER_PIN)
21 |
22 | //#define TSIC_SIGNAL (TSIC_PORT & (1<<TSIC_SIGNAL_PIN))
23 |
24 | // Low/High Signal of the TSIC-Sensor, e.g. "if(TSIC_SIGNAL_HIGH)..."
25 | #define TSIC_SIGNAL_HIGH TSIC_PIN & ( 1 << TSIC_SIGNAL_PIN )
26 | #define TSIC_SIGNAL_LOW !( TSIC_PIN & ( 1 << TSIC_SIGNAL_PIN ))
27 |
28 |
29 | /******************************************************************************
30 | * Function : getTSicTemp(*temp_value16);
31 | * Description : reads from the TSic its output value
32 | * Parameters : pointer for return value
33 | * Returns : 1: reading sucessfull, 0: parity error
34 | ******************************************************************************/
35 | uint8_t getTSicTemp (uint16_t *temp_value16) {
36 |
37 | uint16_t temp_value1 = 0;
38 | uint16_t temp_value2 = 0;
39 | uint8_t i;
40 | uint16_t Temperature;
41 | uint8_t parity;
42 |
43 | TSIC_ON();
44 | _delay_us(60); // wait for stabilization
45 | _delay_us(60);
46 |
47 | while (TSIC_SIGNAL_HIGH); // wait until start bit starts
48 |
49 | // wait, TStrobe
50 | while (TSIC_SIGNAL_LOW);
51 |
52 | // first data byte
53 | // read 8 data bits and 1 parity bit
54 | for (i = 0; i < 9; i++) {
55 | while (TSIC_SIGNAL_HIGH); // wait for falling edge
56 | _delay_us(60);
57 | if (TSIC_SIGNAL_HIGH)
58 | temp_value1 |= 1 << (8-i); // get the bit
59 | else
60 | while (TSIC_SIGNAL_LOW); // wait until line comes high again
61 | }
62 |
63 | // second byte
64 | while (TSIC_SIGNAL_HIGH);
65 | // wait, TStrobe
66 | while (TSIC_SIGNAL_LOW);
67 | // read 8 data bits and 1 parity bit
68 | for (i = 0; i < 9; i++) {
69 | while (TSIC_SIGNAL_HIGH); // wait for falling edge
70 | _delay_us(60);
71 | if (TSIC_SIGNAL_HIGH)
72 | temp_value2 |= 1 << (8-i); // get the bit
73 | else
74 | while (TSIC_SIGNAL_LOW); // wait until line comes high again
75 | }
76 |
77 | TSIC_OFF(); // switch TSic off
78 |
79 | // check parity for byte 1
80 | parity = 0;
81 | for (i = 0; i < 9; i++)
82 | if (temp_value1 & (1 << i))
83 | parity++;
84 | if (parity % 2)
85 | return 0;
86 |
87 | // check parity for byte 2
88 | parity = 0;
89 | for (i = 0; i < 9; i++)
90 | if (temp_value2 & (1 << i))
91 | parity++;
92 | if (parity % 2)
93 | return 0;
94 | temp_value1 >>= 1; // delete parity bit
95 | temp_value2 >>= 1; // delete parity bit
96 | Temperature = (temp_value1 << 8) | temp_value2;
97 | *temp_value16 = Temperature;
98 |
99 | return 1; // parity is OK
100 | }
