1 | #include <avr/io.h>
2 | #include <util/atomic.h>
3 | #include <util/delay.h>
4 | #include <avr/interrupt.h>
5 | #include "avr_compiler.h"
6 |
7 |
8 | /*! \brief CCP write helper function written in assembly.
9 | *
10 | * This function is written in assembly because of the timecritial
11 | * operation of writing to the registers.
12 | *
13 | * \param address A pointer to the address to write to.
14 | * \param value The value to put in to the register.
15 | */
16 | void CCPWrite( volatile uint8_t * address, uint8_t value )
17 | {
18 | volatile uint8_t * tmpAddr = address;
19 |
20 | ATOMIC_BLOCK(ATOMIC_RESTORESTATE)
21 | {
22 | #ifdef RAMPZ
23 | RAMPZ = 0;
24 | #endif
25 | asm volatile(
26 | "movw r30, %0" "\n\t"
27 | "ldi r16, %2" "\n\t"
28 | "out %3, r16" "\n\t"
29 | "st Z, %1" "\n\t"
30 | :
31 | : "r" (tmpAddr), "r" (value), "M" (CCP_IOREG_gc), "i" (&CCP)
32 | : "r16", "r30", "r31"
33 | );
34 | }
35 | }
36 |
37 | /**
38 | * \internal
39 | * \brief Check if RTC32 is busy synchronizing
40 | *
41 | * \retval true Is busy
42 | * \retval false Is ready
43 | */
44 | uint8_t rtc32_is_busy(void)
45 | {
46 | return RTC32.SYNCCTRL & RTC32_SYNCBUSY_bm;
47 | }
48 |
49 | ISR(RTC32_OVF_vect)
50 | {
51 | /* Toggle status led */
52 | PORTR.DIRTGL = PIN0_bm;
53 | }
54 |
55 |
56 | int main(void)
57 | {
58 | /* Apply a resetr of the VBAT */
59 | VBAT.CTRL |= VBAT_ACCEN_bm;
60 |
61 | /* Set access enable bit */
62 | CCPWrite((void *)&VBAT.CTRL, VBAT_RESET_bm);
63 |
64 | /* Enable 32.768kHz crystal oscillator */
65 | VBAT.CTRL |= VBAT_XOSCEN_bm | VBAT_XOSCSEL_bm;
66 |
67 | /* Wait until oscillator is stable */
68 | while(!(VBAT.STATUS & VBAT_XOSCRDY_bm));
69 |
70 | /* Enable low power mode for external oscillator */
71 | OSC.XOSCCTRL = OSC_X32KLPM_bm;
72 |
73 | /* Reset RTC32 module */
74 | RTC32.CTRL = 0;
75 |
76 | /* Wait until sync done */
77 | while(rtc32_is_busy());
78 |
79 | /* Set PER to 1024. CLK source of the RTC32 is 1024 ticks / second = 1 Hz */
80 | RTC32.PER = 1024;
81 |
82 | /* Reset CNT register */
83 | RTC32.CNT = 0;
84 |
85 | /* Wait until sync done */
86 | while(rtc32_is_busy());
87 |
88 | /* Enable overflow interrupts */
89 | RTC32.INTCTRL = RTC32_OVFINTLVL_MED_gc;
90 |
91 | /* Enable real time module */
92 | RTC32.CTRL = RTC32_ENABLE_bm;
93 |
94 | /* Wait until sync done */
95 | while(rtc32_is_busy());
96 |
97 | /* Set port C pin 7 as output */
98 | PORTC.DIRSET = PIN7_bm;
99 |
100 | /* Enable medium priority interrupts */
101 | PMIC.CTRL = PMIC_MEDLVLEN_bm;
102 |
103 | /* Set sleep mode and enable sleep */
104 | SLEEP.CTRL = SLEEP_SMODE_PSAVE_gc | SLEEP_SEN_bm;
105 |
106 | /* Enable global interrupts */
107 | sei();
108 |
109 | while(1)
110 | {
111 | /* Go sleeping */
112 | asm("sleep");
113 | }
114 | }
