Hallo Leute, ich arbeite gerade mit einem M16C62P µ Controller mit IAR. Sobald mein Programm über eine bestimmt Grenze wächst bringt der Linker im IAR folgende Meldung: "Error[e16]: Segment CODE (size: 0x302 align: 0) is too long for segment definition. At least 0x1 more bytes needed. The problem occurred while processing the segment placement command "-Z(HUGECODE)CODE,TINYFUNC=FF0FF-FF3FF", where at the moment of placement the available memory ranges were "CODE:ff0ff-ff3ff"" Im Linker Command File benutze ich folgendes: // ================================================= // IAR XLINK Linker command file for Mitsubishi M16C // For use with the IAR C libraries // // This is an example of a XLINK command file // for the M16C/60 and M16C/20 series. // // $Revision: 1.4 $ // ================================================= // Define CPU -cm16c // Size of the user stack -D_CSTACK_SIZE=400 // Size of the interrupt stack -D_ISTACK_SIZE=40 // Relocatable "bit" segment (must be in data13 area). -Z(BIT)BITVARS=2000-FFFF // ======================= // DATA13 RAM // ======================= -Z(NEAR)DATA13_AN=0-1FFF -Z(NEAR)DATA13_I=400-1FFF -Z(NEAR)DATA13_Z,DATA13_N // ======================= // DATA16 RAM // ======================= // Set up user stack -Z(NEAR)CSTACK+_CSTACK_SIZE=400-7FFF // Set up interrupt stack -Z(NEAR)ISTACK+_ISTACK_SIZE // Near variables -Z(NEAR)DATA16_I,DATA16_Z,DATA16_N,DATA16_AN // User defined near DATA segments // ======================= // DATA16 ROM // ======================= // Constant segments (in ROM), reachable for near pointers -Z(NEARCONST)DATA16_C=8000-FFFF // User defined near CONST segments // ======================= // FAR/DATA20 RAM // ======================= // Far and huge data segments -Z(FAR)FAR_I,FAR_Z,FAR_N,FAR_AN=400-7FFF -Z(HUGE)DATA20_I,DATA20_Z,DATA20_N,DATA20_AN // User defined far & huge DATA segments // ======================= // FAR/DATA20 ROM // ======================= // Constant and initializer segments (in ROM) -Z(FARCONST)FAR_ID=F0000-FFCFF -Z(FARCONST)FAR_C=C0000-FFCFF -Z(HUGECONST)DATA20_C,DATA20_ID,CHECKSUM -Z(FARCONST)DATA16_ID,DATA13_ID,DIFUNCT // CODE segments -Z(HUGECODE)CODE,TINYFUNC=FF0FF-FF3FF -Z(HUGECODE)CSTART=FF000-FF033 // User defined CODE segments // User defined far & huge CONST segments // Variable vector table -Z(CONST)INTVEC=FF4FF-FF5FF // Special page table -Z(CONST)FLIST=FFE00-FFFDB // Fixed interrupt vector table -Z(CONST)INTVEC1=FFFDC-FFFFF // ======================== // IAR C library formatting // ======================== -e_small_write=_formatted_write -e_medium_read=_formatted_read Kann mir jemand von euch mal bitte sein Linker Command File schicken/posten oder einen guten Tipp geben wie ich das Problem umgehen kann. Den Bereich TINYFUNC=FF0FF-FF3FF habe ich auch schon mal auf TINYFUNC=FF0FF-FF4FF erhöht. Leider war ein Absturz beim Upload Vorgang die Folge. Danke für eure Hilfe. Gruß Dirk
Also das Problem mit dem Speicher habe ich jetzt gelöst bzw. war es eigentlich schon. Ich habe nach der Vergrößerung einfach nicht lange genug beim Upload gewartet. Dieser geht jetzt um das 100 fache langsamer. Kann mir jemand sagen warum und was ich dagegen machen kann? Gruß Dirk
Du hast sehr wenig Platz für das Code Segment. -Z(HUGECODE)CODE,TINYFUNC=FF0FF-FF3FF Das sind 768 Byte. Ich nehme an der ROM-Bereich Deines M16C Derivats startet bei C0000. Dann kann der Code auch in dem Bereich liegen. Ersetze mal : -Z(HUGECODE)CODE,TINYFUNC=FF0FF-FF3FF Durch -Z(HUGECODE)CODE=C0000-FF3FF -Z(HUGECODE)TINYFUNC=FF0FF-FF3FF
Das Problem hat sich mittlerweile erledigt ich habe den Speicherbereich so erhöht wie du es auch geschrieben hast. Das Problem mit dem langsamen Upload auch, ich habe einfach den verify deak. und jetzt geht das ganze ziemlich schnell. :) Gruß Dirk
