1 | gregor@gregor-AMILO-Xi-3650:~/Angstrom/setup-scripts$ MACHINE=adb4000 ./oebb.sh bitbake virtual/kernel
2 | Processing bitbake: Fixed to revision b1dbc24ebcc4e5100c32568c2c41fd982fb4bcce, skipping update
3 | Processing meta-angstrom: Current branch angstrom-v2012.05-yocto1.2 is up to date.
4 | Processing meta-openembedded: Current branch denzil is up to date.
5 | Processing meta-ti: Current branch angstrom-staging-yocto1.2 is up to date.
6 | Processing meta-ettus: Fixed to revision 5a6a642f6707dc42a5210dbbf01d2bdfd869d4b0, skipping update
7 | Processing meta-efikamx: Fixed to revision 2c09a3a780b23448e8a6ca964256ff7f5ccba65d, skipping update
8 | Processing meta-nslu2: Fixed to revision 3d9fc951b05b4df476374b6fc3085ebac7f293ee, skipping update
9 | Processing meta-smartphone: Fixed to revision 2b106be01228f64298d6cb338f93088806594344, skipping update
10 | Processing meta-intel: Fixed to revision f75f9b6f68473eb0efac802409608f8389be0030, skipping update
11 | Processing meta-xilinx: Fixed to revision 5191333565f9913b6175bb19485f7320db82080b, skipping update
12 | Processing meta-openpandora: Fixed to revision 9221a48cd088707e0b03f27704c5825fb754bc0c, skipping update
13 | Processing meta-raspberrypi: Current branch denzil is up to date.
14 | Processing meta-handheld: Fixed to revision 1f05a15aceb4c3a19fa070463b58125b5658b2a9, skipping update
15 | Processing meta-opie: Fixed to revision efa3892b20a4ef80274e56e5633ebd62c16f9731, skipping update
16 | Processing meta-java: Fixed to revision 3386ea6c96096f107f43f282f654e5afa456109e, skipping update
17 | Processing meta-browser: Fixed to revision c47f59df2e723495679c751cbdf6a8c6adec4b6a, skipping update
18 | Processing meta-mono: Fixed to revision 83f8233b0498aadb18bf7605c3ba6c71d9e13a3a, skipping update
19 | Processing meta-kde: Fixed to revision 5b0882d951cfd71886d423c190faaa7c7f932333, skipping update
20 | Processing openembedded-core: Current branch denzil is up to date.
21 | Using /home/gregor/.oe/environment-angstromv2012.05 to setup needed variables. It is recommended to do '. /home/gregor/.oe/environment-angstromv2012.05' and run 'bitbake something' without using ./oebb.sh as wrapper
22 | Executing: MACHINE=adb4000 bitbake virtual/kernel
23 | Pseudo is not present but is required, building this first before the main build
24 | DEBUG: Removed the following variables from the environment: OE_BUILD_DIR, DISTRO_DIRNAME, OE_SOURCE_DIR, GNOME_DESKTOP_SESSION_ID, LC_CTYPE, LESSOPEN, GNOME_KEYRING_CONTROL, XDG_SESSION_PATH, LANGUAGE, DEFAULTS_PATH, SHLVL, MANDATORY_PATH, COMPIZ_CONFIG_PROFILE, WINDOWID, IBUS_ENABLE_SYNC_MODE, BBFETCH2, OE_BASE, USERNAME, OE_BUILD_TMPDIR, OE_LAYERS_TXT, LC_MESSAGES, XDG_SEAT_PATH, XDG_CONFIG_DIRS, XDG_CURRENT_DESKTOP, GTK_MODULES, GDMSESSION, LESSCLOSE, UBUNTU_MENUPROXY, OLDPWD, SCRIPTS_BASE_VERSION, BUILDDIR, LS_COLORS, LC_COLLATE
25 | DEBUG: Found bblayers.conf (/home/gregor/setup-scripts/conf/bblayers.conf)
26 | DEBUG: LOAD /home/gregor/setup-scripts/conf/bblayers.conf
27 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-angstrom
28 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/layer.conf
29 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-openembedded/meta-oe
30 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/meta-oe/conf/layer.conf
31 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-openembedded/toolchain-layer
32 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/toolchain-layer/conf/layer.conf
33 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-openembedded/meta-efl
34 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/meta-efl/conf/layer.conf
35 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-openembedded/meta-gpe
36 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/meta-gpe/conf/layer.conf
37 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-openembedded/meta-gnome
38 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/meta-gnome/conf/layer.conf
39 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-openembedded/meta-xfce
40 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/meta-xfce/conf/layer.conf
41 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-openembedded/meta-initramfs
42 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/meta-initramfs/conf/layer.conf
43 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-opie
44 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-opie/conf/layer.conf
45 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-java
46 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-java/conf/layer.conf
47 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-browser
48 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-browser/conf/layer.conf
49 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-mono
50 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-mono/conf/layer.conf
51 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-kde
52 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-kde/conf/layer.conf
53 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-ti
54 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-ti/conf/layer.conf
55 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-efikamx
56 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-efikamx/conf/layer.conf
57 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-nslu2
58 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-nslu2/conf/layer.conf
59 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-smartphone/meta-htc
60 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-smartphone/meta-htc/conf/layer.conf
61 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-smartphone/meta-nokia
62 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-smartphone/meta-nokia/conf/layer.conf
63 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-smartphone/meta-openmoko
64 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-smartphone/meta-openmoko/conf/layer.conf
65 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-smartphone/meta-palm
66 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-smartphone/meta-palm/conf/layer.conf
67 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-handheld
68 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-handheld/conf/layer.conf
69 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-raspberrypi
70 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-raspberrypi/conf/layer.conf
71 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel
72 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/conf/layer.conf
73 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel/meta-sugarbay
74 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/meta-sugarbay/conf/layer.conf
75 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel/meta-crownbay
76 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/meta-crownbay/conf/layer.conf
77 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel/meta-emenlow
78 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/meta-emenlow/conf/layer.conf
79 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel/meta-fishriver
80 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/meta-fishriver/conf/layer.conf
81 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel/meta-fri2
82 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/meta-fri2/conf/layer.conf
83 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel/meta-jasperforest
84 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/meta-jasperforest/conf/layer.conf
85 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/meta-intel/meta-n450
86 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-intel/meta-n450/conf/layer.conf
87 | DEBUG: Adding layer /home/gregor/setup-scripts/sources/openembedded-core/meta
88 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/layer.conf
89 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/bitbake.conf
90 | DEBUG: CONF conf/bitbake.conf:652: including conf/abi_version.conf
91 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/abi_version.conf
92 | DEBUG: CONF conf/bitbake.conf:653: including conf/site.conf
93 | DEBUG: LOAD /home/gregor/setup-scripts/conf/site.conf
94 | DEBUG: CONF conf/bitbake.conf:654: including conf/auto.conf
95 | DEBUG: LOAD /home/gregor/setup-scripts/conf/auto.conf
96 | DEBUG: CONF conf/bitbake.conf:655: including conf/local.conf
97 | DEBUG: LOAD /home/gregor/setup-scripts/conf/local.conf
98 | DEBUG: CONF conf/bitbake.conf:656: including conf/build/x86_64-linux.conf
99 | DEBUG: CONF file 'conf/build/x86_64-linux.conf' not found
100 | DEBUG: CONF conf/bitbake.conf:657: including conf/target/INVALID-oe-linux.conf
101 | DEBUG: CONF file 'conf/target/INVALID-oe-linux.conf' not found
102 | DEBUG: CONF conf/bitbake.conf:658: including conf/machine/adb4000.conf
103 | DEBUG: CONF file 'conf/machine/adb4000.conf' not found
104 | DEBUG: CONF conf/bitbake.conf:659: including conf/machine-sdk/${SDKMACHINE}.conf
105 | DEBUG: CONF file 'conf/machine-sdk/${SDKMACHINE}.conf' not found
106 | DEBUG: CONF conf/bitbake.conf:660: including conf/distro/angstrom-v2012.05.conf
107 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/angstrom-v2012.05.conf
108 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/angstrom-v2012.05.conf:25: including conf/distro/include/sane-srcdates.inc
109 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/sane-srcdates.inc: handle(data, include)
110 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/sane-srcdates.inc
111 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/angstrom-v2012.05.conf:26: including conf/distro/include/sane-srcrevs.inc
112 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/sane-srcrevs.inc: handle(data, include)
113 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/sane-srcrevs.inc
114 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/angstrom-v2012.05.conf:27: including conf/distro/include/angstrom-2010-preferred-versions.inc
115 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-2010-preferred-versions.inc: handle(data, include)
116 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-2010-preferred-versions.inc
117 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/angstrom-v2012.05.conf:136: including conf/distro/include/angstrom.inc
118 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc: handle(data, include)
119 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc
120 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc:52: including conf/distro/include/angstrom-eglibc.inc
121 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-eglibc.inc: handle(data, include)
122 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-eglibc.inc
123 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc:55: including conf/distro/include/angstrom-java.inc
124 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-java.inc: handle(data, include)
125 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-java.inc
126 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc:56: including conf/distro/include/angstrom-jalimo.conf
127 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-jalimo.conf
128 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc:114: including conf/distro/include/angstrom-package-ipk.inc
129 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-package-ipk.inc: handle(data, include)
130 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-package-ipk.inc
131 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc:159: including conf/distro/include/efl-from-svn.inc
132 | DEBUG: BB conf/distro/include/efl-from-svn.inc: handle(data, include)
133 | DEBUG: CONF file 'conf/distro/include/efl-from-svn.inc' not found
134 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom.inc:162: including conf/distro/include/angstrom-core-tweaks.inc
135 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-core-tweaks.inc: handle(data, include)
136 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-core-tweaks.inc
137 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/angstrom-core-tweaks.inc:111: including conf/distro/include/preferred-opie-git-versions.inc
138 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-opie/conf/distro/include/preferred-opie-git-versions.inc: handle(data, include)
139 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-opie/conf/distro/include/preferred-opie-git-versions.inc
140 | DEBUG: CONF /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/angstrom-v2012.05.conf:139: including conf/distro/include/toolchain-internal.inc
141 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/toolchain-internal.inc: handle(data, include)
142 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/conf/distro/include/toolchain-internal.inc
143 | DEBUG: CONF conf/bitbake.conf:661: including conf/distro/defaultsetup.conf
144 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/defaultsetup.conf
145 | DEBUG: CONF /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/defaultsetup.conf:1: including conf/distro/include/default-providers.inc
146 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/default-providers.inc: handle(data, include)
147 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/default-providers.inc
148 | DEBUG: CONF /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/defaultsetup.conf:2: including conf/distro/include/default-versions.inc
149 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/default-versions.inc: handle(data, include)
150 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/default-versions.inc
151 | DEBUG: CONF /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/defaultsetup.conf:3: including conf/distro/include/default-distrovars.inc
152 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/default-distrovars.inc: handle(data, include)
153 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/default-distrovars.inc
154 | DEBUG: CONF /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/defaultsetup.conf:4: including conf/distro/include/world-broken.inc
155 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/world-broken.inc: handle(data, include)
156 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/world-broken.inc
157 | DEBUG: CONF /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/defaultsetup.conf:7: including conf/distro/include/tcmode-default.inc
158 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/tcmode-default.inc: handle(data, include)
159 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/tcmode-default.inc
160 | DEBUG: CONF /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/tcmode-default.inc:59: including conf/distro/include/as-needed.inc
161 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/as-needed.inc: handle(data, include)
162 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/as-needed.inc
163 | DEBUG: CONF /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/defaultsetup.conf:10: including conf/distro/include/tclibc-eglibc.inc
164 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/tclibc-eglibc.inc: handle(data, include)
165 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/distro/include/tclibc-eglibc.inc
166 | DEBUG: CONF conf/bitbake.conf:662: including conf/documentation.conf
167 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/documentation.conf
168 | DEBUG: CONF conf/bitbake.conf:663: including conf/sanity.conf
169 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/conf/sanity.conf
170 | DEBUG: BB configuration INHERITs:0: inheriting classes/base.bbclass
171 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass: handle(data, include)
172 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass
173 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass:3: inheriting classes/patch.bbclass
174 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/patch.bbclass: handle(data, include)
175 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/patch.bbclass
176 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/patch.bbclass:8: inheriting classes/terminal.bbclass
177 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/terminal.bbclass: handle(data, include)
178 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/terminal.bbclass
179 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass:4: inheriting classes/staging.bbclass
180 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/staging.bbclass: handle(data, include)
181 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/staging.bbclass
182 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass:6: inheriting classes/mirrors.bbclass
183 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/mirrors.bbclass: handle(data, include)
184 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/mirrors.bbclass
185 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass:7: inheriting classes/utils.bbclass
186 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/utils.bbclass: handle(data, include)
187 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/utils.bbclass
188 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass:8: inheriting classes/utility-tasks.bbclass
189 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/utility-tasks.bbclass: handle(data, include)
190 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/utility-tasks.bbclass
191 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass:9: inheriting classes/metadata_scm.bbclass
192 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/metadata_scm.bbclass: handle(data, include)
193 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/metadata_scm.bbclass
194 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/base.bbclass:10: inheriting classes/logging.bbclass
195 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/logging.bbclass: handle(data, include)
196 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/logging.bbclass
197 | DEBUG: BB configuration INHERITs:0: inheriting classes/rm_work.bbclass
198 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/rm_work.bbclass: handle(data, include)
199 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/rm_work.bbclass
200 | DEBUG: BB configuration INHERITs:0: inheriting classes/debian.bbclass
201 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/debian.bbclass: handle(data, include)
202 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/debian.bbclass
203 | DEBUG: BB configuration INHERITs:0: inheriting classes/sanity.bbclass
204 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/sanity.bbclass: handle(data, include)
205 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/sanity.bbclass
206 | DEBUG: BB configuration INHERITs:0: inheriting classes/blacklist.bbclass
207 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-openembedded/meta-oe/classes/blacklist.bbclass: handle(data, include)
208 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-openembedded/meta-oe/classes/blacklist.bbclass
209 | DEBUG: BB configuration INHERITs:0: inheriting classes/devshell.bbclass
210 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/devshell.bbclass: handle(data, include)
211 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/devshell.bbclass
212 | DEBUG: BB configuration INHERITs:0: inheriting classes/angstrom-mirrors.bbclass
213 | DEBUG: BB /home/gregor/setup-scripts/sources/meta-angstrom/classes/angstrom-mirrors.bbclass: handle(data, include)
214 | DEBUG: LOAD /home/gregor/setup-scripts/sources/meta-angstrom/classes/angstrom-mirrors.bbclass
215 | DEBUG: BB configuration INHERITs:0: inheriting classes/insane.bbclass
216 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/insane.bbclass: handle(data, include)
217 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/insane.bbclass
218 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/insane.bbclass:25: inheriting classes/package.bbclass
219 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/package.bbclass: handle(data, include)
220 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/package.bbclass
221 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/package.bbclass:41: inheriting classes/packagedata.bbclass
222 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/packagedata.bbclass: handle(data, include)
223 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/packagedata.bbclass
224 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/package.bbclass:42: inheriting classes/prserv.bbclass
225 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/prserv.bbclass: handle(data, include)
226 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/prserv.bbclass
227 | DEBUG: BB configuration INHERITs:0: inheriting classes/buildhistory.bbclass
228 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/buildhistory.bbclass: handle(data, include)
229 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/buildhistory.bbclass
230 | DEBUG: BB configuration INHERITs:0: inheriting classes/sstate.bbclass
231 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/sstate.bbclass: handle(data, include)
232 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/sstate.bbclass
233 | DEBUG: BB configuration INHERITs:0: inheriting classes/package_ipk.bbclass
234 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/package_ipk.bbclass: handle(data, include)
235 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/package_ipk.bbclass
236 | DEBUG: BB configuration INHERITs:0: inheriting classes/image-prelink.bbclass
237 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/image-prelink.bbclass: handle(data, include)
238 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/image-prelink.bbclass
239 | DEBUG: BB configuration INHERITs:0: inheriting classes/license.bbclass
240 | DEBUG: BB /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/license.bbclass: handle(data, include)
241 | DEBUG: LOAD /home/gregor/setup-scripts/sources/openembedded-core/meta/classes/license.bbclass
242 | DEBUG: Clearing SRCREV cache due to cache policy of: clear
243 | DEBUG: Using cache in '/home/gregor/setup-scripts/build/tmp-angstrom_v2012_05-eglibc/cache/bb_codeparser.dat' for codeparser cache
244 | ERROR: OE-core's config sanity checker detected a potential misconfiguration.
245 | Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
246 | Following is the list of potential problems / advisories:
247 |
248 | Please set a valid MACHINE in your local.conf or environment
249 |
250 | ERROR: Execution of event handler 'check_sanity_eventhandler' failed
