1 | /*das ist die Problem Routine, nach deren Aufruf sich das I2c früher oder später aufhängt*/
2 | void motors_onoff_update()
3 | {
4 | uint16_t tim2_ccer, tim3_ccer;
5 |
6 | tim2_ccer |= (uint16_t)(1 << 4) | (uint16_t)(1 << 8) | (uint16_t)(1 << 12);
7 | tim3_ccer |= (uint16_t)(1 << 0) | (uint16_t)(1 << 4) | (uint16_t)(1 << 8);
8 |
9 | TIM2->CCER = tim2_ccer;
10 | TIM3->CCER = tim3_ccer;
11 | }
12 |
13 |
14 |
15 | void timer_init(void)
16 | {
17 | GPIO_InitTypeDef GPIO_InitStructure;
18 | TIM_TimeBaseInitTypeDef TIM_TimeBase_InitStructure;
19 | TIM_OCInitTypeDef TIM_OC_InitStructure;
20 |
21 | //Initialize clocks for TIM2, TIM3
22 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 | RCC_APB1Periph_TIM3, ENABLE);
23 |
24 | //Initialize clocks for GPIOA, GPIOB, AFIO
25 | RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
26 |
27 | //Configure pin TIM2 CH1-CH4 = PA0-PA3, TIM3 CH1-CH2 = PA6,PA7 as alternative function push-pull
28 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_6 | GPIO_Pin_7;
29 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
30 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
31 | GPIO_Init(GPIOA, &GPIO_InitStructure);
32 |
33 | GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
34 | GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
35 | GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
36 | GPIO_Init(GPIOB, &GPIO_InitStructure);
37 |
38 | //Configure TIM2, TIM3 time base
39 | TIM_TimeBase_InitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
40 | TIM_TimeBase_InitStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;
41 | TIM_TimeBase_InitStructure.TIM_Period = 1024-1; //11kHz with F100RB, 35kHz with F103RB
42 | TIM_TimeBase_InitStructure.TIM_Prescaler = 0;
43 |
44 | TIM_TimeBaseInit(TIM2, &TIM_TimeBase_InitStructure);
45 | TIM_TimeBaseInit(TIM3, &TIM_TimeBase_InitStructure);
46 |
47 | //Configure TIM2, TIM3 waveform
48 | TIM_OC_InitStructure.TIM_OCMode = TIM_OCMode_PWM1;
49 | TIM_OC_InitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
50 | TIM_OC_InitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
51 | TIM_OC_InitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
52 | TIM_OC_InitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
53 | TIM_OC_InitStructure.TIM_OutputState = TIM_OutputState_Disable;
54 | TIM_OC_InitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
55 |
56 | TIM_OC_InitStructure.TIM_Pulse = 512;
57 | TIM_OC2Init(TIM2, &TIM_OC_InitStructure);
58 | TIM_OC3Init(TIM2, &TIM_OC_InitStructure);
59 | TIM_OC4Init(TIM2, &TIM_OC_InitStructure);
60 | TIM_OC1Init(TIM3, &TIM_OC_InitStructure);
61 | TIM_OC2Init(TIM3, &TIM_OC_InitStructure);
62 | TIM_OC3Init(TIM3, &TIM_OC_InitStructure);
63 |
64 | /*so hängt sich das I2C irgenwann auf, siehe oben*/
65 | //Set Master/Slave such to synchronize both timers at enable
66 | TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Enable);
67 | TIM_SelectMasterSlaveMode(TIM2, TIM_MasterSlaveMode_Enable);
68 | TIM_SelectInputTrigger(TIM3, TIM_TS_ITR1);
69 | TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Trigger);
70 |
71 | TIM_Cmd(TIM2, ENABLE);
72 | // TIM_Cmd(TIM3, ENABLE); //is enabled by TIM2
73 |
74 | /* würde man die vier Befehle zur Synchronisation nicht benutzen,
75 | aber dafür TIM_Cmd(TIM3, ENABLE) dann funktioniert alles perfekt*/
76 | }
