Forum: Mikrocontroller und Digitale Elektronik Billiger Nichtflüchtiger Speicher über 100 MB !!!???!!!
Autor: Rompf T (Gast)
Hey Freaks,
what is the cheapest non-volatile memory?
I want to design a very very small MP3 Player with VLSI's "vs1001" MP3
Encoder including DAC and Headphoneamplifier, supporting VBR and various
MPX) and an onboard memory für about 90 Minutes of music.
The storage is used to store (erase,store,erase,store,...) those
MP3-Files via (modified) USB-connection and will be placed directly onto
the board (unejectable).
I thought about disassembling anCompactFlash Card, but they are
expensive (in my eyes)
Is there a better solution for 100 MB and above?
Thanx in advance :)
Autor: Fritz7 (Gast)
I think der isn't a cheaper solution, than compact flash cards...
They aren't expensive...!
Your MP3 player only supports MP3?
Have a look at new Formats: Ogg Vobis!
(Sorry for my awful English!)
Fritz7
Autor: Rainer (Gast)
@ Fritz7: Well, I guess its best to keep this discussion in English
though I'm from Austria :)
Anyway, Ogg Vorbis would be great, but it's biggest disadvantage is the
lack of hardware decoders. Using a VS1001K you just have to feed the
decoder with an MP§ bitstream and it does all the work that's needed to
decode the MP3. Ogg still has to be decoded "by hand" meaning you'd have
to either use a DSP in combination with a conventional uC or use a very
powerful uP like eg an ARM - both solutions are not too easy and I guess
quite expensive too (just think about how much you'd have to pay for an
ARM Eval-Board!).
@Rompf: I guess CF is the on of the cheapest memories, and it's biggest
advantage is that it's 100% compatible with an HD, which is even cheaper
BTW, what I forgot: provided that you build a case around the device,
who cares if there's a CF socket in there?
Autor: thkaiser (Gast)
Wird nun in Österreich nur noch englisch gesprochen? ROTFL
Schau Dir das mal an:
http://www.yampp.com
Alles schon drin, auch CF-Unterstützung.
hmpf- man sollte doch den ganzen thread lesen - sorry, dumm
geschwätzt....
@Rompf_T:
Look at the link postet above, there is a complete solution for a
self-made mp3-player, incl. interface for cf-card or hard-disk.
I would prefer cf-cards because of the size and the shock-resistance.
