hi! I'm french (that why i'm writing in english, I hope it's possible to understand me...) and I've a problem. I'm trying to connect to component which common signals are "signed" type. Here is my code : library IEEE; use IEEE.STD_LOGIC_1164.all; --use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_SIGNED.ALL; ------------------------------------------------------------------ -- -- -- you put an angle (integer) and the result is the sinus and -- cosinus of this angle -- ------------------------------------------------------------------ entity Driver_Sram_Vga_conv_cordic is Port ( clk : in std_logic; -- clk card A_integer : in integer range 0 to 65535 ; cos_integer : out integer range 0 to 65535 ; sin_integer : out integer range 0 to 65535 ); end Driver_Sram_Vga_conv_cordic; architecture TransmicionandRecepcion of Driver_Sram_Vga_conv_cordic is ------------------------------------------------------------------- -- -- first component -- ------------------------------------------------------------------- component Conv_integer_signed port( clk : in std_logic; A_integer : in integer range 0 to 65535 ; A_signed : out signed (15 downto 0); cos_signed : in signed (15 downto 0) ; cos_integer : out integer range 0 to 65535 ; sin_signed : in signed (15 downto 0) ; sin_integer : out integer range 0 to 65535 ); end component; ------------------------------------------------------------------- -- -- second component -- ------------------------------------------------------------------- component sc_corproc port( clk : in std_logic; Ain : in signed(15 downto 0); sin : out signed(15 downto 0); cos : out signed(15 downto 0)); end component; ------------------------------------------------------------------- -- -- declaration of the signals to link the 2 blocs -- ------------------------------------------------------------------- signal cos_signed : SIGNED(15 downto 0); signal sin_signed : SIGNED(15 downto 0); -- Observed signals - signals mapped to the output ports of tested entity signal A_signed : SIGNED(15 downto 0); begin ------------------------------------------------------------------- -- -- declaration of the link between the 2 blocs -- ------------------------------------------------------------------- adaptation : Conv_integer_signed port map( clk => clk, A_integer => A_integer, A_signed => A_signed, cos_signed => cos_signed, cos_integer => cos_integer, sin_signed => sin_signed, sin_integer => sin_integer ); Cordic : sc_corproc port map( clk => clk, Ain => A_signed, sin => sin_signed, cos => cos_signed ); end TransmicionandRecepcion; Here is the error message with active HDL : # Error: ELAB1_0021: Driver_Sram_Vga_conv.vhd : (88, 0): Types do not match for port "A_signed". # Error: ELAB1_0021: Driver_Sram_Vga_conv.vhd : (88, 0): Types do not match for port "cos_signed". # Error: ELAB1_0021: Driver_Sram_Vga_conv.vhd : (88, 0): Types do not match for port "sin_signed". Here is the error message withLeonardoSpectrum : line 99: Error, cannot associate type SIGNED for A_signed with type SIGNED for A_signed. line 99: Error, cannot associate type SIGNED for cos_signed with type SIGNED for cos_signed. line 99: Error, cannot associate type SIGNED for sin_signed with type SIGNED for sin_signed. I really don't understand, that doesn't work, if anybody knows why... Thanks a lot, Yves
Hello Yves, please try to use the IEEE.STD_LOGIC_ARITH.ALL, otherwise the type SIGNED may be unknown. Don't know why you commented out that line : --use IEEE.STD_LOGIC_ARITH.ALL; --??
Sorry, that's a copy and paste error!!!! here is my librarys' declaration : library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_SIGNED.ALL; thanks, if you have an other idea...
