1 | #define SINUS_STEPS 25
2 | uint8_t SINUS[SINUS_STEPS] = {126,157,186,213,233,248,255,253,244,228,204,178,148,115,85,55,32,15,4,1,7,19,38,64,93};
3 |
4 | void rtty_maintask(void * pvParameters)
5 | {
6 | rtty_init();
7 |
8 | while(1)
9 | {
10 |
11 | }
12 | }
13 |
14 | void rtty_init(void)
15 | {
16 | NVIC_InitTypeDef NVIC_InitStructure;
17 |
18 | // Timer Interrupt konfigurieren
19 | NVIC_InitStructure.NVIC_IRQChannel = TIM6_DAC_IRQn;
20 | NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
21 | NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
22 | NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
23 | NVIC_Init(&NVIC_InitStructure);
24 |
25 | RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
26 | DMA1_Stream6->CR &= 0xF0100000; //ZKomplett 0 setzen, dabei "reserved" Bits unberührt lassen
27 | DMA1_Stream6->CR |= DMA_SxCR_CHSEL_2 | DMA_SxCR_CHSEL_1 | DMA_SxCR_CHSEL_0; //Channel 7 selected (DAC)
28 | DMA1_Stream6->CR |= DMA_SxCR_PL_1 | DMA_SxCR_PL_0; //Priority very high
29 | DMA1_Stream6->CR |= DMA_SxCR_MINC; //Memory adress pointer is incremented
30 | DMA1_Stream6->CR |= DMA_SxCR_CIRC; //Circular Mode neabled
31 | DMA1_Stream6->CR |= DMA_SxCR_DIR_0; //Memory-to-peripheral
32 | DMA1_Stream6->CR |= DMA_SxCR_PFCTRL; //Peripheral is the flow controller
33 |
34 | DMA1_Stream6->NDTR = SINUS_STEPS; //25 Werte
35 | DMA1_Stream6->PAR = DAC_BASE + 0x1C ; //DAC Adresse
36 | DMA1_Stream6->M0AR = (uint32_t)SINUS; //Lesen aus dem Sinus-Array
37 |
38 | DMA1_Stream6->FCR &= 0xFFFFFF40; //FIFO control register zurück setzen, dabei "reserved" bits unberührt lassen
39 |
40 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
41 | DAC->CR &= 0xC000C000;
42 | DAC->CR |= DAC_CR_DMAEN2; //DAC Channel 2 DMA mode neabled
43 | DAC->CR |= DAC_CR_TEN2; //DAC channel 2 trigger enable
44 | DAC->CR |= DAC_CR_EN2; //DAC Enable
45 |
46 | DMA1->HIFCR |= DMA_HIFCR_CTCIF7 |DMA_HIFCR_CHTIF7 | DMA_HIFCR_CTEIF7 | DMA_HIFCR_CDMEIF7| DMA_HIFCR_CFEIF7; //Clear corresponding flags
47 |
48 | DMA1_Stream6->CR |= DMA_SxCR_EN; //DMA stream enabled
49 |
50 | // Timer 2 konfigurieren
51 | // Sollfrequenz:
52 | // 53,125kHz (2125*25) für MARK -> 15808
53 | // 57,375kHz (2295*25) für SPACE -> 1464
54 | //~11,904nS pro Tick
55 | RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE); // Takt für Timer2 einschalten
56 | TIM6->PSC = 0; //Prescaler 1
57 | TIM6->ARR = 1464; //Autoreload register
58 | TIM6->DIER |= TIM_DIER_UIE; //Interrupt enabled
59 | TIM6->CR2 |= TIM_CR2_MMS_1; //TRGO on Update
60 | TIM6->CR1 |= TIM_CR1_CEN; //Tim6 enable
61 | }
62 |
63 | void TIM6_DAC_IRQHandler(void)
64 | {
65 |
66 | TIM6->SR &= ~TIM_SR_UIF; //Interrupt pending flag zurücksetzen
67 |
68 | GPIOG->ODR ^= GPIO_Pin_14;
69 | }
