php json decoding
Gast #4159854
I tried to parse a JSON file using PHP. But I am stuck now.
This is my JSON file
        "devices": {},
        "rules": {},
        "gui": {},
        "settings": {
                "log-level": 6,
                "pid-file": "..",
                "log-file": "..",
                "webserver-enable": 1,
                "webserver-root": "..",
                "webserver-http-port": 5001,
                "webserver-cache": 1
        "hardware": {
                "433gpio": {
                        "sender": 0,
                        "receiver": 1
        "registry": {
                        "version": {
23
                                "current": "7.0"
24
25
26
27
And this is my PHP so far:
<?php
$json = "config.json";
$jsonIterator = new RecursiveIteratorIterator(
    new RecursiveArrayIterator(json_decode($json, TRUE)),
    RecursiveIteratorIterator::SELF_FIRST);
foreach ($jsonIterator as $key => $val) {
    if(is_array($val)) {
        echo "$key:\n";
    } else {
        echo "$key => $val\n";
24
25
26
27
But it didn’t work? So I appreciate an example for this.
Gast #4160647
I think you need to read the file first before you can parse it.
<?php
$data = file_get_contents($json);
$parsed = json_decode($data, TRUE);
echo "<plaintext>";
print_r($parsed);
(Code not tested)
