have an Hitachi TFT screen cheap one, look at the datasheet. In the datasheet a have 2 connection to made for the timing, the DTMG and DCK. I have an S1D controller like the S1D13706 (datasheet: http://www.erd.epson.com/vdc/pdf/1376/tm/s1d13706tm.pdf) this controller supports a 18bit TFT screen like the one this is. But how must a connect the timing signal of the S1D controller to this TFT screen, on the controller is the FPFRAME,FPLINE,FPSHIFT,DRDY excist as timing signals. I now had is done with a SED1375 look at http://www.reachtech.com/display/slcd-kits.html there a kits made with cld an a SED1375 for the LCD controls. But how must i connect the signals to this TFT screen, please somebody can helpe ?? Regards PJWL
Hello, how did you solve this problem, please??? We'r having a big troubles running EPSON LCD driver S1D13706 with HITACHI display TX14D11VM1CAA. Display redraws only once after reset and then picture stays unchanged regardless whatever we put into the VRAM and picture on the display fades to gray slowly. Display has no VSYNC signal and we don't know how to force it to start redrawing the next frame. Thank You, Mirek. fiala@microtech.cz
