1 | // Serial port demo program
2 | //
3 | // Assumptions: 50Mhz clock rate
4 |
5 | module SerDemo(input uartclk, output ser);
6 |
7 | // Start signal tells it to start sending bits
8 | reg start;
9 |
10 | //The bits of data to send
11 | reg [7:0] data;
12 |
13 | /////////////////////////////////////////////////////////////////////////////
14 | // Serial port clock generator
15 | // Generate a 9600 baud clock signal for the serial port by dividing the
16 | // 50Mhz clock by 5208
17 |
18 | reg [14:0] clockdiv;
19 |
20 | // Count from 0..5207 then reset back to zero
21 | always @(posedge uartclk)
22 | begin
23 | if (clockdiv == 5207)
24 | clockdiv <= 0;
25 | else
26 | clockdiv <= clockdiv + 1;
27 | end
28 |
29 | // The serclock is a short pulse each time we are reset
30 | wire serclock = (clockdiv == 0);
31 |
32 | /////////////////////////////////////////////////////////////////////////////
33 | // Serial port state machine
34 | // Only start the state machine when "start" is set. Only advance to the
35 | // next state when serclock is set.
36 |
37 | reg [3:0] state;
38 |
39 | always @(posedge uartclk)
40 | begin
41 | case (state)
42 | 4'b0000: if (start) state <= 4'b0001;
43 | 4'b0001: if (serclock) state <= 4'b0010; // Start bit
44 | 4'b0010: if (serclock) state <= 4'b0011; // Bit 0
45 | 4'b0011: if (serclock) state <= 4'b0100; // Bit 1
46 | 4'b0100: if (serclock) state <= 4'b0101; // Bit 2
47 | 4'b0101: if (serclock) state <= 4'b0110; // Bit 3
48 | 4'b0110: if (serclock) state <= 4'b0111; // Bit 4
49 | 4'b0111: if (serclock) state <= 4'b1000; // Bit 5
50 | 4'b1000: if (serclock) state <= 4'b1001; // Bit 6
51 | 4'b1001: if (serclock) state <= 4'b1010; // Bit 7
52 | 4'b1010: if (serclock) state <= 4'b0000; // Stop bit
53 | default: state <= 4'b0000; // Undefined, skip to stop
54 | endcase
55 | end
56 |
57 |
58 | ///////////////////////////////////////////////////////////////////////////////
59 | // Serial port data
60 | // Ensure that the serial port has the correct data on it in each state
61 |
62 | reg outbit;
63 |
64 | always @(posedge uartclk)
65 | begin
66 | case (state)
67 | 4'b0000: outbit <= 1; // idle
68 | 4'b0001: outbit <= 0; // Start bit
69 | 4'b0010: outbit <= data[0]; // Bit 0
70 | 4'b0011: outbit <= data[1]; // Bit 1
71 | 4'b0100: outbit <= data[2]; // Bit 2
72 | 4'b0101: outbit <= data[3]; // Bit 3
73 | 4'b0110: outbit <= data[4]; // Bit 4
74 | 4'b0111: outbit <= data[5]; // Bit 5
75 | 4'b1000: outbit <= data[6]; // Bit 6
76 | 4'b1001: outbit <= data[7]; // Bit 7
77 | 4'b1010: outbit <= 1; // Stop bit
78 | default: outbit <= 1; // Bad state output idle
79 | endcase
80 | end
81 |
82 | // Output register to pin
83 | assign ser = outbit;
84 |
85 | ///////////////////////////////////////////////////////////////////////////////
86 | // Test by outputting a letter 'T'
87 |
88 | always @(posedge uartclk)
89 | begin
90 | data = 84; // ASCII 85 = T
91 | start = 1;
92 | end
93 |
94 | endmodule
