Hello folks! I need to design a PCB driver with a FPGA to manage the control signals of several high power IGBT. These IGBTs are going to drive a lot of current (around 7000 Amp) and I need to do a robust PCB design. I have been doing some EMC PCB designs for low power applications (maximum 3 Amp) and they are working very well. However I have never done a EMC PCB design for very high power application and I have been searching some guidelines: http://www.st.com/st-web-ui/static/active/cn/resource/technical/document/application_note/DM00182773.pdf http://www.onsemi.com/pub_link/Collateral/AND9071-D.PDF Therefore I would like to know your opinion about the previous links and if there is anything else that should I have into account to do the PCB design of this IGBT driver… Ahh and finally we are planning to use a Spartan 3A from Xilinx to handle the IGBT control lines. Xilinx is a good manufacturer for this applications or do you think that for this special application there are other manufacturers which can me provide me special EMC/EMI FPGAs?
Just to make this clear: you want to run 7000 amps through a pcb?
He wrote he wants to run 7kA through an IGBT, not through the PCB. But the gate driver PCB will probably be mounted near the high current rails: http://www.ohm.com.tr/images/Product/8ad7ae69-7d54-4bc6-8232-83f92e7deecc_1SD210_ISO3116I.jpg @TO: Do you want to design the whole IGBT driver by yourself, or do you want build a PCB around an OEM gate driver (like them from CT CONCEPT)? If not, I would suffest you to do so.
To save the few cents on commercial drivers ? Ok. Given the 7kA of pulsed current induces false signals into your design by magnetic pickup. In order to minimize coupling you have to minimize loops, specifically the loop areas. Meaning you have to have the relevant traces on the pcb spanning a minimum area. And have the cables twisted.
