hello guys, i need to use the ADC conversion of Atmega32u4 for some analog signals. i read on the datasheet of Atmega32u4 that to do so the "AVCC" pin of the controller must be connected to the input supply voltage pin "VCC" through a LOW PASS filter. my question is: what kind of low pass filter should be appropriate for such task? Thanks in advance
This is a C1-L1-C2 Filter C1=C2 = 100nF L1 aprox. 10µF See ADC Application Notes from Atmel.
