Hallo, ich habe ein Problem mit avrdude 6.3 (Debian stretch) Egal, ob ich fuses lesen oder ein Programm schreiben will, bricht avrdude mit folgender Fehlermeldung (unknown command)ab: avrdude: Send: . [1b] . [07] . [00] . [0c] . [0e] . [10] . [c8] d [64] . [19] [20] . [00] S [53] . [03] . [ac] S [53] . [00] . [00] 4 [34] avrdude: Recv: . [1b] avrdude: Recv: . [07] avrdude: Recv: . [00] avrdude: Recv: . [02] avrdude: Recv: . [0e] avrdude: Recv: . [10] avrdude: Recv: . [00] avrdude: Recv: . [00] avrdude: AVR device initialized and ready to accept instructions Reading | | 0% 0.00savrdude: stk500isp_read_byte(.., signature, 0x0, ...) avrdude: stk500isp_read_byte(): Sending read memory command: avrdude: Send: . [1b] . [08] . [00] . [06] . [0e] . [1b] . [04] 0 [30] . [00] . [00] . [00] 4 [34] avrdude: Recv: . [1b] avrdude: Recv: . [08] avrdude: Recv: . [00] avrdude: Recv: . [02] avrdude: Recv: . [0e] avrdude: Recv: . [1b] avrdude: Recv: . [c9] avrdude: Recv: . [cd] avrdude: stk500v2_command(): unknown command avrdude: stk500isp_read_byte(): timeout/error communicating with programmer avr_read(): error reading address 0x0000 read operation not supported for memory "signature" avrdude: error reading signature data for part "ATmega88", rc=-2 avrdude: error reading signature data, rc=-1 avrdude: Send: . [1b] . [09] . [00] . [03] . [0e] . [11] . [01] . [01] . [0e] avrdude: Recv: . [1b] avrdude: Recv: . [09] avrdude: Recv: . [00] avrdude: Recv: . [02] avrdude: Recv: . [0e] avrdude: Recv: . [11] avrdude: Recv: . [00] avrdude: Recv: . [0f] avrdude done. Thank you. Nach diversen Tests, habe ich avrdude 6.1 installiert, und alles geht wieder wie gewohnt. (kleines Testprogramm) avrdude -b 38400 -B 10 -c stk500v2 -p m88 -P /dev/ttyUSB0 -u -U flash:w:main.hex avrdude: AVR device initialized and ready to accept instructions Reading | ################################################## | 100% 0.03s avrdude: Device signature = 0x1e930a avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "main.hex" avrdude: input file main.hex auto detected as Intel Hex avrdude: writing flash (88 bytes): Writing | ################################################## | 100% 0.20s avrdude: 88 bytes of flash written avrdude: verifying flash memory against main.hex: avrdude: load data flash data from input file main.hex: avrdude: input file main.hex auto detected as Intel Hex avrdude: input file main.hex contains 88 bytes avrdude: reading on-chip flash data: Reading | ################################################## | 100% 0.19s avrdude: verifying ... avrdude: 88 bytes of flash verified avrdude done. Thank you. Das ganze passiert bei 2 Programmern. Diese sind identisch. Da ich diese selber gebaut und das Programm geschrieben habe, denke ich, daß die Ursache in einer neuen Funktion von avrdude liegt. Nur weiß ich nicht, wo ich ansetzen soll, da mir selbst -vvvv nicht weiterhilft. Das gesendet Kommando, wo der Fehler auftritt, sieht meiner Meinung nach OK aus. Kann mir jemand mal weiterhelfen? Danke Jogibär
Hallo, ich habe das Problem gefunden. Die neue avrdude 6.3 nutzt den Befehl CMD_READ_SIGNATURE_ISP, die Version 6.1 nicht. Da werde ich wohl das Programm meiner Programmer erweitern müssen, da ich nur soweit die Befehle implementiert habe, die ich brauchte, um mit avrdude arbeiten zu können. Weiß jemand, warum dies jetzt so gelöst wurde und ob noch mehr verändert wurde? Jogibär
