ich habe mir ein eigenes Makefile geschrieben:
1 | SRCDIRS = src
2 | SRCDIRS+= drv/src
3 | SRCDIRS+= dev
4 |
5 | INCLUDES = -I"dev"
6 | INCLUDES += -I"lib"
7 | INCLUDES += -I"drv/inc"
8 |
9 | CC=arm-none-eabi-gcc
10 |
11 | SRCS = $(foreach srcdir, $(SRCDIRS), $(wildcard $(srcdir)/*.c))
12 | OBJS = $(addprefix bin/, $(subst .c,.o,$(filter %.c,$(SRCS))))
13 | ASMS = $(foreach srcdir, $(SRCDIRS), $(wildcard $(srcdir)/*.s))
14 | ASMO = $(addprefix bin/, $(subst .s,.os,$(filter %.s,$(ASMS))))
15 |
16 | DIRS = $(addprefix bin/, $(SRCDIRS))
17 |
18 | VERSION = `cat src/main.c`
19 |
20 | CFLAGS = -std=gnu99 -march=armv6-m -mcpu=cortex-m0plus -mthumb -Og -fmessage-length=0 -fsigned-char -ffunction-sections
21 | CFLAGS += -fdata-sections -ffreestanding -fno-move-loop-invariants -g3 -Wall -Wextra -Wpedantic -Wno-overflow
22 | CFLAGS += -DSTM32L051xx -DARM_MATH_CM0PLUS -DDEBUG -DPREMIUM
23 |
24 | ASFLAGS = -x assembler-with-cpp
25 |
26 | LDFLAGS = -T dev/STM32L051C8_FLASH.ld -nostartfiles -nodefaultlibs -nostdlib -Xlinker --gc-sections
27 | LIBS = -lc -lm -lnosys -Wl,-Map -Wl,bin/program.map
28 |
29 | .PHONY: all
30 |
31 | all: directories program
32 |
33 | directories:
34 | @mkdir -p ${DIRS}
35 |
36 | program : $(OBJS) $(ASMO)
37 | @echo linking...
38 | @$(CCDIR)$(CC) $(CFLAGS) -o bin/$@.elf $(LDFLAGS) $^ $(LIBS)
39 | @$(CCDIR)arm-none-eabi-size --format=berkeley bin/$@.elf
40 | @$(CCDIR)arm-none-eabi-objcopy -O ihex bin/$@.elf bin/$@.hex
41 | @$(CCDIR)arm-none-eabi-objcopy -O binary bin/$@.elf bin/$@.bin
42 | echo $(VERSION)
43 |
44 | bin/%.o : %.c
45 | @echo compiling $<...
46 | @$(CCDIR)$(CC) $(CFLAGS) $(INCLUDES) -c $< -o $@
47 |
48 | bin/%.os : %.s
49 | @echo compiling $<...
50 | @$(CCDIR)$(CC) $(ASFLAGS) $(CFLAGS) $(INCLUDES) -c $< -o $@
51 |
52 |
53 | .PHONY: clean
54 | clean:
55 | rm -f $(ASMO) $(OBJS)
Ich arbeite mit Eclipse Neon (GCC 5.3). Das Makefile an sich ist kein
Problem. Jedoch bleibt die Ausgabe hängen, wenn ich in den
Projekteigenschaften den Build mit 4 Jobs auswähle:
1 | make -j4 all
2 | compiling src/commands.c...
3 | compiling src/config.c...
4 | compiling src/crc.c...
5 | compiling src/debug.c...
Danach geht es nicht weiter. Wenn ich das make manuell per Kommandozeile
starte läuft alles wunderbar schnell durch. Habt ihr eine Idee, woran es
liegen kann?
