Forum: Mikrocontroller und Digitale Elektronik IAR & MSP430 Timer ISR problem [english response...please]
Autor: Valy Voiculescu (valyv)
Hello(Guten Tag)
1.Do you post answers in english, too?
2.If YES, can someone help me with a timer ISR problem in IAR EW for
Msp430f149?
Autor: Rahul (Gast)
what is the problem?
I did a simple C program for a target board.
I was supposed to blink 2 leds (one in main function and one from
TimerA ISR). The one from main() works (it blinks). The one from TimerA
doesn't (stays off).
When I inspected registers from IAR EW (Debugging with FETDebugger = on
the target board)I noticed that TAR doesn't change.
I'm puzzled...why doesn't timer A start? Is there a problem with the
source code? Is there something about IAR?
I initialised registers for basic clock, watchdog(so it won't reset
the software), timer A, port.
Also on the hardware side: board is powered.
There is an inpuit clock at around ~5MHz available...but for now I went
with DCO.
I can't find anything wrong in C
Below is the source code:
#include <msp430x14x.h>
#include "types.h"
//u8=unsigned char u16=unsigned int
u16 counter=0;
u32 counter2=0;
u8 toggle=0;
u8 toggle2=0;
#pragma vector = TIMERA1_VECTOR  //interupt syntax for IAR 2.x
    __interrupt void timer_isr(void)
    counter++;
    if (counter>32)  //999
        counter=0;
            if (toggle)
                P2OUT &= ~0x04;
            else
                P2OUT |= 0x04;
            toggle ^=1;
void main()
    WDTCTL = WDTPW + WDTHOLD;
    P2SEL = 0x00;
  P2DIR = 0xff;
  P2OUT = 0xff;
  P2IE  = 0x00;
  P2IFG = 0x00;
  P2IES = 0x00;
     DCOCTL = DCO0 + DCO1 + DCO2;
    BCSCTL1 = XT2OFF + RSEL0 + RSEL1 + RSEL2 ;
  BCSCTL2 = 0;
    TAR = 0;
  TACTL = MC_0;
   //external input clock ~5MHz although not used
     TACCR0=999;
    TACTL = TASSEL_1 + ID_0 + MC_1 +TAIE;
//TACTL= TASSEL_2  + ID_3+MC_1+TAIE;
  _EINT();
  __bis_SR_register(GIE);
  while(1)
    counter2++;
        if (counter2>20000)
            counter2=0;
            if (toggle2)
                P2OUT &= ~0x02;
                //P2OUT=0x00;
            else
                //P2OUT &= ~0x02; //0x4;
                P2OUT|=0x02;
            toggle2 ^=1;
Autor: Bepi (Gast)
Hi
I think you have forget to enable the Capture/compare Interrupt.
Add to your source :
TACCTL0 = CCIE; // IRQ enable
hope this will work
CU
Bepi
