Hello I use the evaluation version of the IAR workbench and the Renesas KD30 debugger to debug the M16C/6N4. I have tried to create a demo C++ application, but I can't link the application, since I get the "Fatal Error[e119]: Cannot handle C++ identifiers in this output format" error. This is because the output format doesn't support C++ (IAR has been setup to support C++). How do I then create an C++ application in IAR running with the KD30 debugger? Which output format must be used? Currently I use the IEEE-695 output format, which works with C, but not C++. I have created an release version, which runs C++ with the Motorola output format. This works fine. Thanks Denker
