DC-DC Wandler mit MCP42010
OP #5235618
  ich arbeite zZ mit LM25117-Q1 ein dc-dc wandler (buck), damit möchte
ich MCP42010 (digital POTI) ankopplen. Die MCP42010 ist ein 12 Pin IC
(document und diagram im amhäng).
 Die Feedback output von die erste LM25117-Q1 dc-dc wandler soll ich mit
dieser MCP42010 digi pot adjustieren. Ich bin nicht sicher aber welce
PIN passt dass mit, ob mit die PW0, PW1 (die wiper output - feedback pin
Wei soll ich den eigentlich die pinning ankloppen.
 Vielen Dank im Vorhaus!
 Bhargav
OP #5235646
 English is better to explain,
 I am currently working on project design of power supply for Automotive
 This power supply is a switching mode power regulator
 The first SMPS IC "LM25117-Q1" 20 PIN IC  outputs positive voltage
(upto
 40V), it has a FB pin with which I thought of using a digi
Potentiometer to adjust the output voltage with its wiper resistance.
 It is 12PIN MCP42010 with SPI interface, which will be controlled by
the
 dsPIC30f4011 controller (mit CAN ANSCHLUSS).
 My question is I am which pins should I used or connect the FB pin of
my DC-DC converter with MCP42010 digi POT.
 I am currently creating this symbols in Ltspice so I can have a proper
connections pin-pin
 Thanks
Gast #5235692
I would prefer a DAC plus an OP-AMP instead of the digital
potentiometer.
The DAC generates a programmable reference volatage. The OP-AMP compares
that with the current output voltage. If the output voltage is too high,
then the OP-AMP outputs a high voltage. If the output voltage is lower
than it should be, then the OP_AMP outputs a low voltage.
The output of the OP-AMP is connected to the COMP input of the buck
controller.
So that replaced the fixed internal reference voltage of the bock
controller by an programmeable external one. As far as I know, it is
important that the OP-AMP does not amplify the deviation too much,
otherwise the circiut might oscillate.
Another similar approach without OP-AMP is described here:
https://www.maximintegrated.com/en/app-notes/index.mvp/id/818
Another method with OP-AMP would be to generate the reference volate
with PWM and a low-pass filter instead of a DAC.
OP #5235709
Thank you for your reply
  The thing is I have already the parts (Digital Potentiometer, MCP42010
and
  also some other parts for the design.
  The approach of using a DAC can also be considered but the thing with
DAC
  is I could not find them with SPI interface, with which I can use them
with
  DSPIC30F4011 the controller in my design
  So, had to shift for the option of to use digi POT IC
  Bhargav
