Hallo zusammen.
Ich versuche seit Tagen mit einem Arduino Nano und einem MAX31855K
Temperaturen zu messen. Der Fühler ist ebenfalls ein K-Typ. An meinem
Multimeter zeigt er die richtige Temperatur an.
Der Sketch ist der Beispiel-Sketch von Adafruit.
1 | /***************************************************
2 | This is an example for the Adafruit Thermocouple Sensor w/MAX31855K
3 |
4 | Designed specifically to work with the Adafruit Thermocouple Sensor
5 | ----> https://www.adafruit.com/products/269
6 |
7 | These displays use SPI to communicate, 3 pins are required to
8 | interface
9 | Adafruit invests time and resources providing this open source code,
10 | please support Adafruit and open-source hardware by purchasing
11 | products from Adafruit!
12 |
13 | Written by Limor Fried/Ladyada for Adafruit Industries.
14 | BSD license, all text above must be included in any redistribution
15 | ****************************************************/
16 |
17 | #include <SPI.h>
18 | #include "Adafruit_MAX31855.h"
19 |
20 | // Default connection is using software SPI, but comment and uncomment one of
21 | // the two examples below to switch between software SPI and hardware SPI:
22 |
23 | // Example creating a thermocouple instance with software SPI on any three
24 | // digital IO pins.
25 | #define MAXDO 3
26 | #define MAXCS 4
27 | #define MAXCLK 5
28 |
29 | // initialize the Thermocouple
30 | Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
31 |
32 | // Example creating a thermocouple instance with hardware SPI
33 | // on a given CS pin.
34 | //#define MAXCS 10
35 | //Adafruit_MAX31855 thermocouple(MAXCS);
36 |
37 | void setup() {
38 | while (!Serial); // wait for Serial on Leonardo/Zero, etc
39 |
40 | Serial.begin(9600);
41 |
42 | Serial.println("MAX31855 test");
43 | // wait for MAX chip to stabilize
44 | delay(500);
45 | }
46 |
47 | void loop() {
48 | // basic readout test, just print the current temp
49 | Serial.print("Internal Temp = ");
50 | Serial.println(thermocouple.readInternal());
51 |
52 | double c = thermocouple.readCelsius();
53 | if (isnan(c)) {
54 | Serial.println("Something wrong with thermocouple!");
55 | } else {
56 | Serial.print("C = ");
57 | Serial.println(c);
58 | }
59 | //Serial.print("F = ");
60 | //Serial.println(thermocouple.readFarenheit());
61 |
62 | delay(1000);
63 | }
Als Ergebnis kommt dies dabei rum:
Internal Temp = -56.00
C = -931.75
Internal Temp = 97.00
C = -64.00
Internal Temp = -62.00
C = -505.75
Internal Temp = -80.00
C = -387.75
Internal Temp = -96.00
C = -124.75
Internal Temp = -100.00
C = -1087.25
Internal Temp = 32.00
C = -1262.25
Internal Temp = 0.00
C = -1146.25
C = -1166.50
Internal Temp = -58.00
C = -1063.25
Internal Temp = -64.00
C = -1043.75
Im Anhang sind der Schaltplan und ein paar Bilder.
Kann mir da einer helfen?
Kalli
