Dear all i am trying to set up a buffer through Usart and trying to send some data through this buffer .below is my function for the buffer i wanted to ask if my function is correct or not .? ofcourse it is not the whole program.just wanted to know if i have made the function correct. your response will be highly aprreciated void USART_Puts(USART_TypeDef* USARTx,volatile char *s) { while(*s) { while(USART_GetFlagStatus(USART3, USART_FLAG_TXE) == RESET); USART_SendData(USARTx,*s); *s++; } } void TxMessage(COM_BYTE *Buffer, COM_UINT16 count) { int i=0; for (i=0;i<count;i++) { USART_Puts(USART3, Buffer); } while(1) { // sprintf(str, "i am USART_3 "); // USART_Puts(USART3,str); UI_16 Test[10]; Test[0]='H'; Test[1]='a'; Test[2]='l'; Test[3]='l'; Test[4]='o'; Test[5]=' '; Test[6]=' '; Test[7]=' '; Test[8]='e'; Test[9]='o'; TxMessage (Test,10); }
No, it isn't correct. If you can't figure out why, read a book on C programming 101. Or test it. Sooner or later you'll figure out why. Hint: It may seem to work at some times but not at others.
