1 | //Abschnitt der Main Funktion:
2 | uint8_t Login_Password_Byte[4] = {0x00, 0x00, 0x00, 0x00}; /*defined as a global variable
3 | void AskForPassword(void)
4 | { UART_sendCString("Default password (j/n)?: ");
5 |
6 | while(UART_Not_Recieved)
7 | {
8 |
9 | }
10 | UART_putNewLine();
11 | UART_Not_Recieved = true;
12 | if(RX == 0x6A)
13 | {
14 | Login_Password_Byte[0] = 0x00;
15 | Login_Password_Byte[1] = 0x00;
16 | Login_Password_Byte[2] = 0x00;
17 | Login_Password_Byte[3] = 0x00;
18 |
19 | }else{
20 | UART_sendCString("Please enter a valid 4 character password: ");
21 |
22 | while(UART_Not_Recieved)
23 | {
24 |
25 | }
26 | Login_Password_Byte[0] = RX;
27 | UART_Not_Recieved = true;
28 | while(UART_Not_Recieved)
29 | {
30 |
31 | }
32 | Login_Password_Byte[1] = RX;
33 | UART_Not_Recieved = true;
34 | while(UART_Not_Recieved)
35 | {
36 |
37 | }
38 | Login_Password_Byte[2] = RX;
39 | UART_Not_Recieved = true;
40 | while(UART_Not_Recieved)
41 | {
42 |
43 | }
44 | Login_Password_Byte[3] = RX;
45 | UART_Not_Recieved = true;
46 | UART_putNewLine();
47 | }
48 | }
49 | //Abschnitt der LOGIN Funktion
50 | oid Login(uint8_t Byte1, uint8_t Byte2, uint8_t Byte3, uint8_t Byte4)
51 | {
52 | uint8_t ui8Offset = 0;
53 | g_pui8TrfBuffer[ui8Offset++] = 0x8F; // Reset FIFO
54 | g_pui8TrfBuffer[ui8Offset++] = 0x91; // Send with CRC
55 | g_pui8TrfBuffer[ui8Offset++] = 0x3D; // Write Continuous
56 | g_pui8TrfBuffer[ui8Offset++] = 0x00; //length
57 | g_pui8TrfBuffer[ui8Offset++] = 0xF0; // length
58 | g_pui8TrfBuffer[ui8Offset++] = 0x22; // ISO15693 flags
59 | g_pui8TrfBuffer[ui8Offset++] = 0xE4; // Login command code
60 | g_pui8TrfBuffer[ui8Offset++] = 0x16; //IC Mfg Code
61 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[0]; // Tag UID
62 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[1]; // Tag UID
63 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[2]; // Tag UID
64 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[3]; // Tag UID
65 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[4]; // Tag UID
66 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[5]; // Tag UID
67 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[6]; // Tag UID
68 | g_pui8TrfBuffer[ui8Offset++] = g_pui8Iso15693UId[7]; // Tag UID
69 |
70 | g_pui8TrfBuffer[ui8Offset++] = Byte1; // Password
71 | UART_putByte(Byte1);
72 | g_pui8TrfBuffer[ui8Offset++] = Byte2;
73 | UART_putByte(Byte2);
74 |
75 | g_pui8TrfBuffer[ui8Offset++] = Byte3;
76 | UART_putByte(Byte3);
77 |
78 | g_pui8TrfBuffer[ui8Offset++] = Byte4;
79 | UART_putByte(Byte4);
80 | TRF79xxA_writeRaw(&g_pui8TrfBuffer[0], ui8Offset); // Issue the write Password command
81 | g_sTrfStatus = TRF79xxA_waitRxData(5,15); // 5 millisecond TX timeout, 15 millisecond RX timeout
82 |
83 | if (g_sTrfStatus == RX_COMPLETE) // If data has been received
84 | {
85 | if (g_pui8TrfBuffer[0] == 0x00) // Confirm "no error" in response flags byte
86 | {
87 | UART_sendCString(" Login successful ");
88 | UART_putNewLine();
89 | }
90 | else
91 | {
92 | UART_sendCString(" Login failed (wrong password)");
93 | Write_Data = false;
94 | New_Password = false;
95 | Change_Protect_Status = false;
96 | UART_putNewLine();
97 | }
98 | }
99 | }
