(V) ImageCraft C-Compiler für AVR-Controller
OP #6806116
- Imagecraft: www.imagecraft.com
- Version: JumpStart C for AVR STD, Version 8, Dongle-Version
- Neupreis: 249€
- Windows-Version: Windows-XP bis Windows-10
- Manual online:
  "https://imagecraft.com/help/iccavr/wwhelp/wwhimpl/js/html/wwhelp.htm";
- 45 Tage-Demo-Version: "https://imagecraft.com/download/demo-software";
- Main Features:
  - Loads fast, runs fast, professional yet easy-to-use.
  - Supports all tinyAVR (with SRAM), AVR, megaAVR, and XMEGA devices.
  - IDE with workspace/project management, syntax-aware features, code
    browsing, code completion, etc.
  - No need to write linker command files. Select the target device by
    name, and our tools do the rest.
  - Fast ANSI C conformant compilers written from the ground up (not
based
    on GCC), optimized for microcontroller targets.
  - Full set of compiler tools including C compiler, assembler, linker
and
    library file manager.
  - Produces standard format output files, interspersed C and asm
listing
    files, and symbolic debug files.
  - Machine-Independent Optimization:
    - Algebraic simplification.
    - Switch statement optimization.
  - Automatic generation of AVR bit instructions and other AVR-specific
    instructions.
  - Native debugger, integrated with the IDE.
  - Built-in flash downloader.
  - Integrated JumpStart Debugger (separate license required to enable
full
    functionality)
  - Code size limited to 64K bytes of flash.
Verkaufspreis: 130€ (incl. Dongle)
               awlager@googlemail.com
