1 | $ make
2 | [ 12%] Building CXX object googletest/CMakeFiles/gtest.dir/src/gtest-all.cc.obj
3 | In file included from C:/MinGW/googletest/googletest/include/gtest/gtest-message.h:55,
4 | from C:/MinGW/googletest/googletest/include/gtest/gtest-assertion-result.h:46,
5 | from C:/MinGW/googletest/googletest/include/gtest/gtest.h:59,
6 | from C:\MinGW\googletest\googletest\src\gtest-all.cc:38:
7 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1244:8: error: 'mutex' in namespace 'std' does not name a type
8 | std::mutex mu_;
9 | ^~~~~
10 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1244:3: note: 'std::mutex' is defined in header '<mutex>'; did you forget to '#include <mutex>'?
11 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:758:1:
12 | +#include <mutex>
13 | #endif // GTEST_IS_THREADSAFE
14 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1244:3:
15 | std::mutex mu_;
16 | ^~~
17 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1245:8: error: 'condition_variable' in namespace 'std' does not name a type
18 | std::condition_variable cv_;
19 | ^~~~~~~~~~~~~~~~~~
20 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1245:3: note: 'std::condition_variable' is defined in header '<condition_variable>'; did you forget to '#include <condition_variable>'?
21 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:758:1:
22 | +#include <condition_variable>
23 | #endif // GTEST_IS_THREADSAFE
24 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1245:3:
25 | std::condition_variable cv_;
26 | ^~~
27 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h: In member function 'void testing::internal::Notification::Notify()':
28 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1231:26: error: 'mutex' is not a member of 'std'
29 | std::lock_guard<std::mutex> lock(mu_);
30 | ^~~~~
31 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1231:26: note: 'std::mutex' is defined in header '<mutex>'; did you forget to '#include <mutex>'?
32 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1231:26: error: 'mutex' is not a member of 'std'
33 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1231:26: note: 'std::mutex' is defined in header '<mutex>'; did you forget to '#include <mutex>'?
34 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1231:31: error: template argument 1 is invalid
35 | std::lock_guard<std::mutex> lock(mu_);
36 | ^
37 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1231:38: error: 'mu_' was not declared in this scope
38 | std::lock_guard<std::mutex> lock(mu_);
39 | ^~~
40 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1233:5: error: 'cv_' was not declared in this scope
41 | cv_.notify_all();
42 | ^~~
43 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1233:5: note: suggested alternative: 'gcvt'
44 | cv_.notify_all();
45 | ^~~
46 | gcvt
47 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1231:33: warning: unused variable 'lock' [-Wunused-variable]
48 | std::lock_guard<std::mutex> lock(mu_);
49 | ^~~~
50 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h: In member function 'void testing::internal::Notification::WaitForNotification()':
51 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1239:27: error: 'mutex' is not a member of 'std'
52 | std::unique_lock<std::mutex> lock(mu_);
53 | ^~~~~
54 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1239:27: note: 'std::mutex' is defined in header '<mutex>'; did you forget to '#include <mutex>'?
55 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1239:27: error: 'mutex' is not a member of 'std'
56 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1239:27: note: 'std::mutex' is defined in header '<mutex>'; did you forget to '#include <mutex>'?
57 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1239:32: error: template argument 1 is invalid
58 | std::unique_lock<std::mutex> lock(mu_);
59 | ^
60 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1239:39: error: 'mu_' was not declared in this scope
61 | std::unique_lock<std::mutex> lock(mu_);
62 | ^~~
63 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1240:5: error: 'cv_' was not declared in this scope
64 | cv_.wait(lock, [this]() { return notified_; });
65 | ^~~
66 | C:/MinGW/googletest/googletest/include/gtest/internal/gtest-port.h:1240:5: note: suggested alternative: 'gcvt'
67 | cv_.wait(lock, [this]() { return notified_; });
68 | ^~~
69 | gcvt
70 | make[2]: *** [googletest/CMakeFiles/gtest.dir/src/gtest-all.cc.obj] Error 1
71 | make[1]: *** [googletest/CMakeFiles/gtest.dir/all] Error 2
72 | make: *** [all] Error 2
