Sodala ich hab einen AT89C2051 mit dem DS1820 verbunden, leider hängt das Programm bei der while (ReadByte()==0xff); // wait for conversion complete Zeile im ReadTemp UP. Hat jemand einen Plan? sbit DQ = P1^3; // connect with DS1820 Data pin //--------------------------------------- // Delay mS function //--------------------------------------- void DelayMs(unsigned int count) { // mSec Delay 11.0592 Mhz unsigned int i; // Keil v7.5a while(count) { i = 115; while(i>0) i--; count--; } } //---------------------------------------- // DELAY at 11.0592MHz crystal. // Calling the routine takes about 22us, and then // each count takes another 17us. // test with KEIL C51 V7.5 //---------------------------------------- void DelayUs(int us) { int i; for (i=0; i<us; i++); } //---------------------------------------- // Reset DS1820 //---------------------------------------- bit ResetDS1820(void) { bit presence; DQ = 0; //pull DQ line low DelayUs(29); // leave it low for about 490us DQ = 1; // allow line to return high DelayUs(3); // wait for presence 55 uS presence = DQ; // get presence signal DelayUs(25); // wait for end of timeslot 316 uS return(presence); // presence signal returned } // 0=presence, 1 = no part //----------------------------------------- // Read one bit from DS1820 //----------------------------------------- bit ReadBit(void) { unsigned char i=0; DQ = 0; // pull DQ low to start timeslot DQ=1; for (i=0; i<3; i++); // delay 17 us from start of timeslot return(DQ); // return value of DQ line } //----------------------------------------- // Write one bit to DS1820 //----------------------------------------- void WriteBit(bit Dbit) { unsigned char i=0; DQ=0; DQ = Dbit ? 1:0; DelayUs(5); // delay about 39 uS DQ = 1; } //----------------------------------------- // Read 1 byte from DS1820 //----------------------------------------- unsigned char ReadByte(void) { unsigned char i; unsigned char Din = 0; for (i=0;i<8;i++) { Din|=ReadBit()? 0x01<<i:Din; DelayUs(6); } return(Din); } //----------------------------------------- // Write 1 byte //----------------------------------------- void WriteByte(unsigned char Dout) { unsigned char i; for (i=0; i<8; i++) // writes byte, one bit at a time { WriteBit((bit)(Dout & 0x1)); // write bit in temp into Dout = Dout >> 1; } DelayUs(5); } //----------------------------------------- // Read temperature //----------------------------------------- void ReadTemp(unsigned char * buff) { unsigned char n; EA=0; // disable all interrupt ResetDS1820(); WriteByte(0xcc); // skip ROM WriteByte(0x44); // perform temperature conversion while (ReadByte()==0xff); // wait for conversion complete ResetDS1820(); WriteByte(0xcc); // skip ROM WriteByte(0xbe); // read the result for (n=0; n<9; n++) // read 9 bytes but, use only one byte { buff[n]=ReadByte(); // read DS1820 } EA=1; }
Hey Jankey,ich verwend momentan ebenfalls den ds1820,den quellcode den du da angefügt hast,der stimmt,hab ich auch und bei mir zeigt er keine fehler ein,wo möglich hast du falsche einstellung beim keil! Ich hab das problem,dass er mir nichts auf den display anzeigt!
