Hallo habe meine Folientastatur (http://www1.conrad.de/conrad/layout2/detail.fh?fh_secondid=b2c709930&layout=layout2&fh_host=www1.conrad.de&fh_eds=%c3%9f&do_fh_search=1&fh_session=%2fscripts%2fwgate%2fzcop_b2c%2f~flN0YXRlPTEyNTUxODc1MTQ%3d&fh_location=%2f%2fb2cconrad_de_b2c%2fde_DE&fh_search=folientastatur&fh_refview=search) folgendermaßen angeklemmt: die ersten drei leitungen (Spalten) PORTC0-2 die anderen 4 (Zeilen) an PORTC3-6 Hier das Prog ======================================================================== ==== void main(void) { //////////////////////////////////////// //// Variablendeklarationen //// //////////////////////////////////////// char Zahl; Zahl = 0; //////////////////////////////////////// //// Portbelegungen //// //////////////////////////////////////// DDRA = 0xff; //Port A als Ausgang definieren[Display] DDRC |= 0x07; //Port C0-2 als Ausgang DDRC &= 0x07; //Port C3-6 als Eingang PORTC |= 0x78; //enable pull-ups C3-6 //////////////////////////////////////// //// Displayinitialisierung //// //////////////////////////////////////// //lcd_init(LCD_DISP_ON); lcd_init(LCD_DISP_ON); lcd_clrscr(); lcd_gotoxy(0,1); lcd_puts("Ready"); lcd_gotoxy(0,0); while(1) { //// Spalte_1 //// PORTC |= 0x07; //Port C0-2 auf HIGH setzen PORTC &= 0xFE; //Port C0 LOW setzen [Spalte 1] if( ( PINC & ( 1 << PC3 ) ) == 0 ) //Zeile_1 { Zahl = 1; lcd_puts("1"); } _delay_ms(50); if( ( PINC & ( 1 << PC4 ) ) == 0 ) //Zeile_2 { Zahl = 4; lcd_puts("4"); } _delay_ms(50); if( ( PINC & ( 1 << PC5 ) ) == 0 ) //Zeile_3 { Zahl = 7; lcd_puts("7"); } _delay_ms(50); if( ( PINC & ( 1 << PC6 ) ) == 0 ) //Zeile_4 { Zahl = '*'; lcd_puts("*"); } _delay_ms(50); //// Spalte_2 //// PORTC |= 0x07; //Port C0-2 auf HIGH setzen PORTC &= 0xFD; //Port C1 LOW setzen [Spalte 2] if( ( PINC & ( 1 << PC3 ) ) == 0 ) //Zeile_1 { Zahl = 2; lcd_puts("2"); } _delay_ms(50); if( ( PINC & ( 1 << PC4 ) ) == 0 ) //Zeile_2 { Zahl = 5; lcd_puts("5"); } _delay_ms(50); if( ( PINC & ( 1 << PC5 ) ) == 0 ) //Zeile_3 { Zahl = 8; lcd_puts("8"); } _delay_ms(50); if( ( PINC & ( 1 << PC6 ) ) == 0 ) //Zeile_4 { Zahl = '0'; lcd_puts("0"); } _delay_ms(50); //// Spalte_3 //// PORTC |= 0x07; //Port C0-2 auf HIGH setzen PORTC &= 0xFB; //Port C2 LOW setzen [Spalte 3] if( ( PINC & ( 1 << PC3 ) ) == 0 ) //Zeile_1 { Zahl = 3; lcd_puts("3"); } _delay_ms(50); if( ( PINC & ( 1 << PC4 ) ) == 0 ) //Zeile_2 { Zahl = 6; lcd_puts("6"); } _delay_ms(50); if( ( PINC & ( 1 << PC5 ) ) == 0 ) //Zeile_3 { Zahl = 9; lcd_puts("9"); } _delay_ms(50); if( ( PINC & ( 1 << PC6 ) ) == 0 ) //Zeile_4 { Zahl = '#'; lcd_puts("#"); } _delay_ms(50); } } ======================================================================== = so wenn ich nun mein ATMega16 damit flashe, dann erscheint die ganze zeit nur 2 auf dem Display, als wäre die ganze zeit die taste für 2 gedrückt.... Danke !
Ich habe mir dein Programm nicht angesehen, aber bei mir war es so dass die Taste 7 "geklemmt" hat. Bis ich die Tastatur aufgeklebt hatte. Aber ich denke das hast du nachgemessen.
Ja richtig, habe die Tastatur durchgemessen, also da klemmt nichts, wäre ja auch zu schön bei einer nagelneuen tastatur, aber aufgeklebt habe ich sie allerdings auch noch nicht.... woran könnte es denn schätzungsweise noch liegen ? also die abfrage ist gleich wie bei all den anderen, halt nur angepasst.... if( ( PINC & ( 1 << PC3 ) ) == 0 ) //Zeile_1 { Zahl = 2; lcd_puts("2"); } _delay_ms(50); und sonst änder ich an dem port ja auch nichts....
Wie wärs mal mit einem einfacheren Testpgm das dir die 3 Pinwerte einfach mal so wie sie abgelesen werden ausgibt? Dann siehst du sofort ob es an deiner Auswertung (die ich nicht kontrolliert habe) liegt, oder ob von der Taste tatsächlich ständig was gemeldet wird.
Ne brauch ich nicht, habe die folientastatur ja komplett durchgemmesen... da kommt absolut nichts an ....
> Ne brauch ich nicht
Na ja, wenn du meinst.
Die Hardware ist es nicht, die Software ist es nicht.
Also müsste es eigentlich funktionieren.
Was kommt als nächstes? Compilerfehler?
Warum wartest du nach jedem Pin-Test 50ms ? So wie ich das sehe, wartest Du 12*50ms - liest also nur alle 600ms den Tastaturstatus. schönerer quelltext (wenn nicht nach Anzahl Zeilen bezahlt): mach mal: zahl = -1; switch (!PINC) { case (1 << PC3): Zahl=1; break; case (1 << PC4): Zahl=2; break; .... } if (zahl != -1) lcd_put(ord(`0`) + zahl);
Wenns nach dem geht, würde ich das so machen (Ausserdem bin ich
tippfaul)
char SpaltenPin[] = { 0x01, 0x02, 0x04 );
char Spalte[3][4] = { { 1, 4, 7, '*' },
{ 2, 5, 8, 0 },
{ 3, 6, 9, '#' } };
char CharSpalte[3][] = { { "147*" },
{ "2580" },
{ "369#" } };
zahl = -1;
for( i = 0; i < 3; ++i ) {
PORTC = ~SpaltenPin[i]; // Port C die Spalte auswählen
// Das Schaltet auch unnötigerweise
// die Pullups immer wieder ein,
// aber das macht nichts.
Index = ( PINC & 0x78 ) >> 3;
if( Index > 0 ) {
zahl = Spalte[i][Index];
lcd_putc( CharSpalte[i][Index] );
_delay_ms(50);
aber das ist eine andere Geschichte.
auch sehr schön - und vor allem recht laufzeitoptimal tippfaul ? glaub ich jetzt irgendwie nicht ;-)
> auch sehr schön
nur hats einen (kleinen) Schönheitsfehler.
Es funktioniert so nicht :-)
Ist aber kein Problem, ist leicht behebbar.
Tip: In Index ist jeweils eines von 4 Bit gesetzt
wenn die Taste gedrückt wurde. Das heist aber nicht,
dass das dann die Zahlen von 0 bis 4 ergibt.
Abhilfe: Die Codierarrays auf 16 Einträge erweitern.
Habs auch erst jetzt bei erneutem Durchlesen gemerkt :-)
