Hallo, ich habe ein kleines Problem mit einen LCD Display, ich kann zwar Daten hinschicken, die auch angezeigt werden, allerdings hab ich keine Ahnung wie ich sie positionieren soll. Das LCD Display fängt immer am Anfang der ersten Zeile an...ich hab aber keine Ahnung wie ich in die zweite komm! #include <msp430x12x2.h> ;----------------------------------------------------------------------- ------- ; initialisation ;----------------------------------------------------------------------- ------- RESET ORG 0E000h ; Flash mov #WDTPW + WDTHOLD, &WDTCTL ; stop call #LCD_INIT eint ;----------------------------------------------------------------------- ------- main mov #1, R10 mov #000h, R11 call #SEND ; first nibble of display clear mov #1, R10 mov #001h, R11 call #SEND ; send 'U' to display (ASCII 4Dh) bis.b #BIT1, &P3OUT ; RS = 1 means data mov #1, R10 mov #005h, R11 ; high-nibble first call #SEND mov #1, R10 mov #005h, R11 ; low-nibble call #SEND bic.b #BIT1, &P3OUT ; ;----------------------------------------------------------------------- ------- ; LCD initialisation sub routine ;----------------------------------------------------------------------- ------- LCD_INIT mov.b #000h, &P1OUT ; set data lines DB4-DB7 mov.b #00fh, &P1DIR mov.b #000h, &P3OUT ; set EN and RS line mov.b #003h, &P3DIR mov #16, R10 ; counter (16 * 1ms) call #DELAY ; wait R10 * 1ms mov #003h, R11 ; standard init routine mov #5, R10 call #SEND ; send init code first time mov #1, R10 call #SEND ; send init code second time mov #1, R10 call #SEND ; send init code third time mov #1, R10 mov #002h, R11 call #SEND ; define 4-Bit communication mov #1, R10 mov #002h, R11 call #SEND ; first nibble of function set mov #1, R10 mov #008h, R11 call #SEND ; second nibble of function set ; 2 lines, 5x7 dots mov #1, R10 mov #000h, R11 call #SEND ; first nibble of display control mov #1, R10 mov #00Ch, R11 call #SEND ; second nibble of display control ; display on, cursor off mov #1, R10 mov #000h, R11 call #SEND ; first nibble of display clear mov #1, R10 mov #001h, R11 call #SEND ; second nibble of display clear mov #1, R10 mov #000h, R11 call #SEND ; first nibble of entry mode set mov #1, R10 mov #006h, R11 call #SEND ; second nibble of entry mode set ; increment address counter ret ;-------------------------------- ---------------------------------------------- ; send Data via Port1 (P1.0-P1.3) to LCD - subroutine ;----------------------------------------------------------------------- ------- SEND bis.b #BIT0, &P3OUT ; EN = 1 mov.b R11, &P1OUT ; data to DB4-DB7 bic.b #BIT0, &P3OUT ; EN = 0 call #DELAY ret ;----------------------------------------------------------------------- ------- ; Delay - sub routine ;----------------------------------------------------------------------- ------- DELAY mov #03E8h,R12 ; value for counting back LOOP dec R12 jnz LOOP dec R10 ; multipier for LOOP jnz DELAY ret ; ; Interrupt Vectors Used MSP430x1232 ;----------------------------------------------------------------------- ------- ORG 0FFFEh ; MSP430 RESET Vector DW RESET END
Du musst die DD RAM ADDRESS setzen mit Kommando 0b001xxxxx, wobei xxxxx die Adresse ist. Vorsicht, die Adressen sind nicht ganz linear verteilt. Siehe Datenblatt. MFG Falk
