Viele Warnungen beim Kompilieren
Gast #473957
ich kriege folgende Warnings beim compilieren mit WinAVR gcc:
webcam/mca25.c:79: warning: pointer targets in passing argument 3 of 'mca25_grab_data' differ in signedness
webcam/mca25.c:114: warning: pointer targets in passing argument 3 of 'mca25_grab_data' differ in signedness
webcam/mca25.c: In function 'mca25_start_image_grab':
webcam/mca25.c:391: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:410: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:433: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:434: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c: In function 'mca25_init':
webcam/mca25.c:491: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:500: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:508: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:517: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:525: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:534: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:544: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:553: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:562: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:573: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:584: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:604: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:617: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
webcam/mca25.c:625: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
23
webcam/mca25.c:660: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
24
webcam/mca25.c: In function 'mca25_configure':
25
webcam/mca25.c:698: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
26
webcam/mca25.c:711: warning: pointer targets in passing argument 1 of 'strncmp_P' differ in signedness
27
webcam/mca25.c: In function 'mca25_pgm_send':
28
webcam/mca25.c:777: warning: 'old[2]' may be used uninitialized in this function
29
webcam/mca25.c:777: warning: 'old[1]' may be used uninitialized in this function
30
webcam/mca25.c:777: warning: 'old[0]' may be used uninitialized in this function
Sind die Warnungen Gefährlich?
Gast #473963
Heisst nur, dass du der Variablen zu diesem Zeitpunkt nichts zugwiesen
hast. Ein Auslesen würde undefinerte Werte liefern.
klingt nach verschiedenen Variablentypen.
Du versuchst "strncmp_P" einen unerwarteten Pointertype zu übergeben.
Das machst du mehrfach, und auch mit anderen Funktionen.
Da das Warnings sind, funktioniert das Programm (zumindest ist es
syntaktisch richtig), kann aber ungewollte Ergenisse liefern.
#473980
Es empfiehlt sich aber trotzdem, den Code soweit zu
korrigieren, dass alle Warnings wieder verschwinden.
Viele Warnings sind zwar harmlos, aber nicht alle.
Und die gehen dann in der Flut der harmlosen Warnings
unter.
Gast #474038
Jede Warnung ist solange gefährlich, bis man genau verstanden hat, warum
sie auftritt, (und sie als ungefährlich einstufen kann). Nur kann (und
sollte) man dann auch gleich den Code so ändern, daß sie nicht mehr
auftritt :-)
Oliver
#1536168
Ich klinke mich bei dem Thread mal ein weil es so schön dazu passt. Ich
bekomme auch die signedness Fehlermeldung, weiss aber nicht, wie ich sie
beheben soll:
in der main.c führe ich folgenden Befehl aus, der eine Funktion in
Stephan Buskers FAT16 Library aufruft:
fopen_("file0001.txt",'a');
die Lib sieht so aus:
extern File *  fopen_(s8 *fname,s8 mode);
Es sird also eine signed Zeichenfolge erwartet. Wie kann ich ihm dieses
festlegen?
mit fopen_(signed char test = "file0001.txt",'a');
funktioniert es auch nicht.
Gast #1536187
Dann ist diese Funktion falsch deklariert. Der erste Parameter müßte
eigentlich vom Typ const char* sein. Dann käme auch keine Warnung.
Genau das ist das Problem. Wenn man mit Strings arbeitet, sollte es
vollkommen egal sein, ob der für Zeichen verwendete Typ nun ein
Vorzeichen hat oder nicht.
> Wie kann ich ihm dieses festlegen?
Du wirst wohl einen cast bemühen müssen:
fopen_((s8*)"file0001.txt",'a');
