Was bedeutet der Fehler? Ich vermute, das hat was mit Interruptvektoren
zu tun.
Hier das Programm:
.include "m8def.inc"
.def tmp1 = R16
ldi tmp1,HIGH(RAMEND)
out SPH,tmp1
ldi tmp1,LOW(RAMEND)
out SPL,tmp1
.equ MPORT = PORTC
.equ IN1 = PC0
.equ IN2 = PC1
.equ IN3 = PC2
.equ IN4 = PC3
.equ ENA = PC4
.equ ENB = PC5
reset:
ldi tmp1, 0xFF
out DDRC, tmp1
cbi DDRD, PD2 //Taster1, ENon
cbi DDRD, PD3 //Taster2, ENoff
sbi DDRD, PD5 //Led1
sbi DDRD, PD6 //Led2, EN Status
sbi PORTD, PD6
cbi MPORT, ENA
cbi MPORT, ENB
ldi tmp1, (1<<WGM21)|(1<<CS22)|(1<<CS21)|(1<<CS20) //CTC Modus
out TCCR2, tmp1
ldi tmp1, (1<<OCIE2) //CTC Interrupt enable
out TIMSK, tmp1
ldi tmp1, 0xF0
out OCR2, tmp1
rjmp main
.org OC2addr //Compare Match Interrupt
rjmp match
main:
sbic PIND, PD2 //Taster abfrage
rcall ENon
sbic PIND, PD3
rcall ENoff
rjmp main
match:
sbis PIND, PD5
rjmp LED1on
sbic PIND, PD5
rjmp LED1off
LED1on:
sbi PORTD, PD5
reti
LED1off
cbi PORTD, PD5
reti
ENon:
sbi PORTD, PD6
sbi MPORT, ENA
sbi MPORT, ENB
ret
ENoff:
cbi PORTD, PD6
cbi MPORT, ENA
cbi MPORT, ENB
ret
