Forum: Mikrocontroller und Digitale Elektronik SRF08
Autor: clemens (Gast)
hat dieses modul schon mal wer verwendet?
falls ja eventuell auch mit nem ATMEGA?
hätt da nämlich meinen code nur funzt der net so wie er sollte!
wär cool wenn mir da wer helfen könnte!
  Two wire serial Interface for the ATMEGA 16 microcontroller.
  It is used to communicate with our own EEPROM, which purpose is it
  to store the measured data from the amp.
  programmed by Christoph Lex
#include<io.h>
#include<iom32.h>
#include<interrupt.h>
#define START   0x08
#define SLA_ACK 0x18
#define DAT_ACK 0x28
#define R_START 0x10
#define R_SLA_ACK 0x40
#define DTA_REC 0x50
void TWI_send(unsigned char ucDatabyte, unsigned char ucSLAVE_W,
unsigned char ucByteaddress);
unsigned char TWI_rec(unsigned char ucSLAVE_R, unsigned char
ucByteaddress, unsigned char ucSLAVE_W);
void Timer_1ms(int Time);
void Timer_10us(int Time);
void main()
  unsigned char ucByteaddress;
  unsigned char ucSLAVE_W;
  int i=0;
  DDRB = 0xFF;
  TWBR = 0x01;
  ucSLAVE_W = 0xE0;
  ucByteaddress = 0x00;
   TWI_send(0x51,ucSLAVE_W,ucByteaddress);
  Timer_1ms(50);
//   PORTB = ~TWI_rec(0xE1,0x03,0xE0);
  TWCR = (1<<TWINT)|(1<<TWSTA)|(1<<TWEN); // clear interrupt flag and
initiate START condition
  while(!(TWCR & (1<<TWINT)))    // wait for interrupt flag
  if ((TWSR & 0xF8) != START)    // check if the value from the ack
matches the START cond.
    PORTB = ~0xFE;
  TWDR = ucSLAVE_W;        // Slave - address + Write command are
written in the TWI data register
  TWCR = (1<<TWINT)|(1<<TWEN);  // clear flag and enable TWI
  if ((TWSR & 0xF8) != SLA_ACK)    // check if the value from the ack
matches the SLAVE_address cond.
    PORTB = ~0xFD;
  TWDR = ucByteaddress;      // Byteaddress is written into the data
register
  if ((TWSR & 0xF8) != DAT_ACK)
    PORTB = ~0xFC;
  TWDR = ucDatabyte;        // Databyte is written into the data
register
  if ((TWSR & 0xF8) != DAT_ACK)    // check if the value from the ack
matches the DATA_send cond.
    PORTB = ~0xFB;
  TWCR = (1<<TWINT)|(1<<TWEN)|(1<<TWSTO); // transmit STOP condition
    PORTB = ~0xFA;
  if ((TWSR & 0xF8) == START)    // check if the value from the ack
    PORTB = ~0x0E;
  if ((TWSR & 0xF8) == SLA_ACK)    // check if the value from the ack
    PORTB = ~0x0D;
register
  if ((TWSR & 0xF8) == DAT_ACK)
    PORTB = ~0x0A;
  if ((TWSR & 0xF8) == R_START)    // check if the value from the ack
    PORTB = ~0x09;
  TWDR = ucSLAVE_R;        // Slave - address + READ command are written
  if ((TWSR & 0xF8) == R_SLA_ACK)    // check if the value from the ack
    PORTB = ~0x08;
  return TWDR;
  int i;
  for(i=0;i<Time;i++)
    Timer_10us(100);
  int i;
  for(i=0;i<Time*3;i++)
thx a lot!
Autor: atomino (Gast)
ohne deinen code jetzt zu lesen
meine erfahrung:
I2C  100khz nicht höher
min 6..7 messungen  1..2 messeungen immer sinnlos
range runtersetzen sonst grössere gefahr fuer störung (4m)
bei mir funzt es
muss mal den code raussuchen
ach so ldr spinnt bei mir manchmal
gruesse
