Kann mir jemand sagen, wie ich die
AT91SAM7X64-RAM.Id abändern muss, damit sie dem Speicher des
AT91SAM7X256 entspricht? Oder kann man die Datei irgendwo herunterladen?
Habe über google leider nichts finden können.
AT91SAM7X64-RAM.Id sieht folgendermaßen aus:
/* Memory Definitions */
MEMORY
CODE (rx) : ORIGIN = 0x00000000, LENGTH = 0x00003000 /*12K*/
DATA (rw) : ORIGIN = 0x00003000, LENGTH = 0x00001000 /* 4K*/
STACK (rw) : ORIGIN = 0x00004000,LENGTH = 0x00000000
/* Section Definitions */
SECTIONS
/* first section is .text which is used for code */
. = 0x0000000;
.text : { *cstartup.o (.text) }>CODE =0
.text :
*(.text) /* remaining code */
*(.glue_7t) *(.glue_7)
} >CODE =0
. = ALIGN(4);
/* .rodata section which is used for read-only data (constants) */
.rodata :
*(.rodata)
} >CODE
. = ALIGN(4);
_etext = . ;
PROVIDE (etext = .);
/* .data section which is used for initialized data */
.data : AT (_etext)
_data = . ;
*(.data)
SORT(CONSTRUCTORS)
} >DATA
. = ALIGN(4);
_edata = . ;
PROVIDE (edata = .);
/* .bss section which is used for uninitialized data */
.bss :
__bss_start = . ;
_bss_start_ = . ;
*(.bss)
*(COMMON)
. = ALIGN(4);
_bss_end_ = . ;
_bss_end_ = . ;
_end = .;
. = ALIGN(4);
.int_data :
*(.internal_ram_top)
}> STACK
PROVIDE (end = .);
/* Stabs debugging sections. */
.stab 0 : { *(.stab) }
.stabstr 0 : { *(.stabstr) }
.stab.excl 0 : { *(.stab.excl) }
.stab.exclstr 0 : { *(.stab.exclstr) }
.stab.index 0 : { *(.stab.index) }
.stab.indexstr 0 : { *(.stab.indexstr) }
.comment 0 : { *(.comment) }
/* DWARF debug sections.
Symbols in the DWARF debugging sections are relative to the
beginning
of the section so we begin them at 0. */
/* DWARF 1 */
.debug 0 : { *(.debug) }
.line 0 : { *(.line) }
/* GNU DWARF 1 extensions */
.debug_srcinfo 0 : { *(.debug_srcinfo) }
.debug_sfnames 0 : { *(.debug_sfnames) }
/* DWARF 1.1 and DWARF 2 */
.debug_aranges 0 : { *(.debug_aranges) }
.debug_pubnames 0 : { *(.debug_pubnames) }
/* DWARF 2 */
.debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) }
.debug_abbrev 0 : { *(.debug_abbrev) }
.debug_line 0 : { *(.debug_line) }
.debug_frame 0 : { *(.debug_frame) }
.debug_str 0 : { *(.debug_str) }
.debug_loc 0 : { *(.debug_loc) }
.debug_macinfo 0 : { *(.debug_macinfo) }
/* SGI/MIPS DWARF 2 extensions */
.debug_weaknames 0 : { *(.debug_weaknames) }
.debug_funcnames 0 : { *(.debug_funcnames) }
.debug_typenames 0 : { *(.debug_typenames) }
.debug_varnames 0 : { *(.debug_varnames) }
Ich nehme mal an man muss nur
in
CODE (rx) : ORIGIN = 0x00000000, LENGTH = 0x00008000 /*32K*/
DATA (rw) : ORIGIN = 0x00008000, LENGTH = 0x00008000 /*32K*/
STACK (rw) : ORIGIN = 0x00010000,LENGTH = 0x00000000
abändern. Oder muss man sonst noch auf etwas achten?
