Synthesizer blind?
Gast #520819
Hallo!
Habe folgenden Testcode gebaut. Sinn soll später mal sein das ich ein
SRAM beschreiben kann.
Wie ihr aber sehen könnt denkt der Synthesizer das ich da weder mit
meiner Clock gearbeitet hab noch will er mein ram_a_data assignment
sehen.
Was hab ich denn da falsch gemacht?? Vielleicht kann ja jemand mal
schnell drüberschauhen...
Gruß,
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity top is
port (
  clock: in std_logic;
  led : out std_logic_vector(7 downto 0);
  ram_addr : out std_logic_vector(17 downto 0);
  ram_we : out std_logic;
  ram_oe : out std_logic;
  ram_a_data : inout std_logic_vector(7 downto 0);
  ram_a_ce : out std_logic;
  ram_a_lb : out std_logic;
  ram_a_ub : out std_logic );
end top;
architecture Behavioral of top is
signal srwrite : std_logic;
signal counter : std_logic_vector(10 downto 0) := (others => '0');
signal addr_in : std_logic_vector(17 downto 0) := (others => '0');
component sram is
port (
  srwrite : in std_logic;
  addr_in : in std_logic_vector(17 downto 0);
end component;
begin
  swr: sram
  port map (
    clock => clock,
    srwrite => srwrite,
    addr_in => addr_in,
    ram_addr => ram_addr,
    ram_we => ram_we,
    ram_oe => ram_oe,
    ram_a_data => ram_a_data,
    ram_a_ce => ram_a_ce,
    ram_a_lb => ram_a_lb,
    ram_a_ub => ram_a_ub );
  process (clock)
  begin
    if (clock'event and clock = '1') then
      if (counter < "00000001000") then
        --write data
        srwrite <= '1';
        ram_a_data  <= counter (7 downto 0);
        addr_in <= addr_in + '1';
        --ram_addr <= address;
          --  conv_std_logic_vector(counter, 18); error multisource
        -- srwrite <= '0';
        --  ram_a_data <= ( others => 'Z' );
      end if;
      counter <= counter + 1;
    end if;
  end process;
end Behavioral;
Synthesizing Unit <sram>.
    Related source file is "C:/VHDL/uart_send_sram/sram.vhd".
WARNING:Xst:647 - Input <clock> is never used.
WARNING:Xst:2563 - Inout <ram_a_data<0>> is never assigned. Tied to
value Z.
WARNING:Xst:2563 - Inout <ram_a_data<1>> is never assigned. Tied to
value Z.
WARNING:Xst:2563 - Inout <ram_a_data<2>> is never assigned. Tied to
value Z.
WARNING:Xst:2563 - Inout <ram_a_data<3>> is never assigned. Tied to
value Z.
WARNING:Xst:2563 - Inout <ram_a_data<4>> is never assigned. Tied to
value Z.
WARNING:Xst:2563 - Inout <ram_a_data<5>> is never assigned. Tied to
value Z.
WARNING:Xst:2563 - Inout <ram_a_data<6>> is never assigned. Tied to
value Z.
WARNING:Xst:2563 - Inout <ram_a_data<7>> is never assigned. Tied to
value Z.
auch noch einen kleinen hinweis :
selbst wenn deine deine sram komponente den ram_a_data verwendet, was
hat dann das :
für eine funktion (zumal der ram_a_data doch von deiner sram komponente
"gestellt" wird)
noch ein kleiner tipp :
bezieht sich doch auf deine sram komponente. alle folgenden fehler
beziehen sich darauf (bis ein weiteres "Related source file is ..."
folgt ...)
such vielleicht da erst mal, bevor du den synthesizer "anzweifelst" (ist
nicht immer verkehrt, aber oftmals hat der schon recht ....)
  • [vhdl]VHDL-Code[/vhdl]
