Forum: Mikrocontroller und Digitale Elektronik BUG PIC18F2550
von Ron N. (blitzgeist)
kann mir jemand erklären oder an Hand von Code zeigen wie ich den
workaround in die Microchip fw einbinde, der im Datenblatt unter
17.5.1.1 gezeigt ist, sodass der PIC nicht immer in den suspend mode
geht?
lg
blitzgeist
von Kloberscht (Gast)
17.5.1.1?
Ich hab mir jetzt exakt das aktuellste Datenblatt gezogen, ich finde
dieses Kapitel nicht. Wovon sprichst du?
BTW: hab gerade gesehen, dass das Datenblatt noch immer den Status
"Preliminary" hat. kopfschüttel
Hi Kloberscht,
daspdf hat den Namen 39632D. Google mal, erster Eintrag. Ja und das
Kapitel 17.5.1.1 steht aus Seite 179. Das Kapitel heißt: Bus Activity
Detect Interrupt Bit(ACTVIF). Von anderen Quellen habe ich das hier:
You should first understand why you have been suspended, and what your
duties as a device are in this state.
You will always be suspended 3ms after plugging in the device because
the host won't send SOFs before it has reset the device, so there is no
activity on the bus, so you must go into suspend mode until the resume
signal is received.
In the suspend state you must ensure that you do not draw more than the
permitted suspend current, which probably means that you must go into
'sleep' mode on the PIC.
The code as originally written by Microchip tended to work correctly
except that it was left up to the coder/designer to ensure that the
current drawn was in specification for the suspend state (by entering
sleep mode).
Unfortunately the PIC18F2550 has a bug in the suspend/resume logic,
which was not known to Microchip at the time that they wrote the
framework code. This resulted in a failure to resume correctly if the
timing was slightly changed in the code. This bug they have chosen to
document in later versions of the data sheet as normal operation, so see
17.5.1.1 Bus Activity Detect Interrupt Bit (ACTVIF) in the 'c release of
the data sheet. I solved this bug by a different procedure myself, but I
am informed that the Microchip workaround is also effective.
Das workaround sieht so aus(aus dem Datenblatt):
UCONbits.SUSPND = 0;
while (UIRbits.ACTVIF) { UIRbits.ACTVIF = 0; }
Doch wo füge ich das in der firmware genau ein?
Dachte hier:
void USBWakeFromSuspend(void)
     * If using clock switching, this is the place to restore the
     * original clock frequency.
    UIEbits.ACTVIE = 0;
    UIRbits.ACTVIF = 0;
}//end USBWakeFromSuspend
Doch ohne Erfolg! Mir gehen echt bald die Ideen aus, wie ich diesen
Fehler beheben könnte. Was mich nur wundert ist das es bei
sprut(http://www.sprut.de/electronic/pic/8bit/18f/programm/usb2550/usb2550.htm)
alles so einwandfrei funzt.
Wer kann mir da weiterhelfen?
lg,
blitzgeist
