1 | void PWM_init( void )
2 | {
3 | unsigned int Tmp;
4 |
5 | g_PeriodTime = DEFAULT_PERIOD;
6 | g_ListOfDutyCycles[0] = DEFAULT_PULSE;
7 | g_NRofDefPulse = DEFAULT_NR_OF_DEF_PULSE;
8 | g_CountNextPulseNR = 0;
9 |
10 | // Enable User Reset and set its minimal assertion to 960 us
11 | // AT91C_RSTC_URSTIEN == AT91C_SYSC_URSTIEN
12 | //AT91C_BASE_RSTC->RSTC_RMR = AT91C_RSTC_URSTIEN | (0x4<<8) | (unsigned int)(0xA5<<24);
13 |
14 |
15 | // First, enable the clock of the PIO
16 | //AT91C_ID_PIOA ((unsigned int) 2) // Parallel IO Controller
17 | AT91F_PMC_EnablePeriphClock ( AT91C_BASE_PMC, 1 << AT91C_ID_PIOA ) ;
18 |
19 | // then, we configure the PIO Lines corresponding to LED1 to LED4
20 | // to be outputs. No need to set these pins to be driven by the PIO because it is GPIO pins only.
21 | ////////////////////////////////////////////////AT91F_PIO_CfgOutput( AT91C_BASE_PIOA, LED_MASK ) ;
22 |
23 | // Clear the output (LEDs on)
24 | ////////////////////////////////////////////////AT91F_PIO_SetOutput( AT91C_BASE_PIOA, 0 ) ;
25 |
26 | // now initializes PWM
27 |
28 | // Enabling a PWM output through the PIO, peripheral A, PA0
29 | AT91F_PIO_CfgPeriph(AT91C_BASE_PIOA, AT91C_PA0_PWM0, 0);
30 |
31 | // Configure PMC by enabling PWM clock
32 | AT91F_PWMC_CfgPMC ();//LED1 on
33 | AT91F_PWMC_StopChannel(AT91C_BASE_PWMC,AT91C_PWMC_CHID0);
34 |
35 | // Set the Clock A divider
36 | AT91C_BASE_PWMC->PWMC_MR = (( PWM_SCALER << 8 ) | PWM0_DIVIDER);
37 |
38 | // Set the Clock
39 | // - divider clock A
40 | // - CALG=0 Left aligned
41 | // - CPOL=1 sart at High level (0 inverse output)
42 | // - CPD=0 update the dute cycle
43 | AT91C_BASE_PWMC_CH0->PWMC_CMR = AT91C_PWMC_CPRE_MCKA | CPD_OFF | CPOL_ON | CALG_OFF ; //LED1 Aus???
44 |
45 | // Set the Period register (sample size bit fied )
46 | AT91C_BASE_PWMC_CH0->PWMC_CPRDR = g_PeriodTime;//Period;
47 | // Set the duty cycle register (output value)
48 | AT91C_BASE_PWMC_CH0->PWMC_CDTYR = g_ListOfDutyCycles[0];//Pulse0;
49 | // Initialise the Update register write only
50 | AT91C_BASE_PWMC_CH0->PWMC_CUPDR = DEFAULT_NEXT_PULSE;//Pulse1;
51 |
52 |
53 | // Now start the PWM channel
54 | AT91F_PWMC_StartChannel(AT91C_BASE_PWMC,AT91C_PWMC_CHID0);//LED1 Blinking
55 |
56 |
57 | /* Open PWM interrupt*/
58 | //AT91SAM64.h neue definitions schreibweise
59 | // #define AT91C_AIC_SRCTYPE ((unsigned int) 0x3 << 5) // (AIC) Interrupt Source Type
60 | // #define AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE ((unsigned int) 0x0 << 5) // (AIC) Internal Sources Code Label Level Sensitive
61 |
62 | /*AT91SAM256.h neue definitions schreibweise*/
63 | // #define AT91C_AIC_SRCTYPE ((unsigned int) 0x3 << 5) // (AIC) Interrupt Source Type
64 | // #define AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL ((unsigned int) 0x0 << 5) // (AIC) Internal Sources Code Label High-level Sensitive
65 | AT91F_AIC_ConfigureIt( AT91C_BASE_AIC,
66 | AT91C_ID_PWMC,
67 | PWM_INTERRUPT_LEVEL,
68 | AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL,
69 | PWM_handler);
70 |
71 | AT91F_AIC_EnableIt(AT91C_BASE_AIC, AT91C_ID_PWMC);
72 |
73 | // Enable IRQ
74 | AT91F_PWMC_InterruptEnable(AT91C_BASE_PWMC,AT91C_PWMC_CHID0);
75 | Tmp = AT91C_BASE_PWMC->PWMC_ISR;
76 | Tmp = Tmp;
77 | }
78 | void PWM_handler(void)
79 | {
80 | unsigned int Tmp;
81 | // Hand check the interrupt
82 | Tmp = AT91C_BASE_PWMC->PWMC_ISR;
83 | Tmp = Tmp;
84 |
85 | //Initialise the Update register write only
86 | if(g_ListOfDutyCycles[ g_CountNextPulseNR]!=0)
87 | {
88 | if(g_CountNextPulseNR<g_NRofDefPulse)// aktuelle periode < anzahl der perioden
89 | {
90 |
91 | AT91C_BASE_PWMC_CH0->PWMC_CUPDR =g_ListOfDutyCycles[ g_CountNextPulseNR++ ];
92 |
93 | if(g_CountNextPulseNR >= g_NRofDefPulse)// Counter overflow set back
94 | g_CountNextPulseNR=0;
95 | }
96 | else
97 | {
98 | g_CountNextPulseNR=0;//rücksetzten des counters
99 | }
100 | }
101 |
102 | // Set the Period register (sample size bit fied )
103 | AT91C_BASE_PWMC_CH0->PWMC_CPRDR =g_PeriodTime;
104 |
105 | irqCntr++;
106 |
107 | }
108 |
109 | void PWM_pos(){
110 | AT91C_BASE_PWMC_CH0->PWMC_CMR = AT91C_PWMC_CPRE_MCKA | CPD_OFF| CPOL_ON| CALG_OFF;
111 | }
112 | void PWM_neg(){
113 | AT91C_BASE_PWMC_CH0->PWMC_CMR = AT91C_PWMC_CPRE_MCKA | CPD_OFF| CPOL_OFF| CALG_OFF;
114 | }
