Hallo, ich versuche mich zur Zeit am ersten Interruptprogrämmchen mit meinem neuen ARM vo Atmel und stoße auf ein komisches Problem für mich. Eine LED soll ganz normal über einen delay blinken und die andere durch einen Tastendruck, also durch einen Interrupt. Hier ist mal die main und die dazugehörige ISR: MAIN.C: ------------------------------------------------ #include "AT91SAM7S256.h" #include "board.h" #include "delay.h" #include "stdlib.h" #include "string.h" void button2irqhandler (void); extern void LowLevelInit(void); extern unsigned enableIRQ(void); void LowLevelInit(); int main (void) { // Set up the LEDs (PA0 - PA3) volatile AT91PS_PIO pPIO = AT91C_BASE_PIOA; // pointer to PIO data structure pPIO->PIO_PER = LED_MASK | Button1; // PIO Enable Register - allow PIO to control pins P0 - P2 and pin 19 pPIO->PIO_OER = LED_MASK; // PIO Output Enable Register - sets pins P0 - P2 to outputs pPIO->PIO_SODR = LED_MASK; // PIO Set Output Data Register - turns off the two LEDs // Select PA19 (pushbutton) to be IRQ function (Peripheral B) pPIO->PIO_BSR = Button2; // Set up the AIC registers for Button2 volatile AT91PS_AIC pAIC = AT91C_BASE_AIC; // pointer to AIC data structure pAIC->AIC_IDCR = (1<<AT91C_ID_IRQ0); // Disable timer 0 interrupt in AIC Interrupt Disable Command Register pAIC->AIC_SVR[AT91C_ID_IRQ0] = // Set the Button2 IRQ handler address in AIC Source (unsigned int)button2irqhandler; // Vector Register[12] pAIC->AIC_SMR[AT91C_ID_IRQ0] = // Set the interrupt source type and priority (AT91C_AIC_SRCTYPE_INT_HIGH_LEVEL | 0x4 ); // in AIC Source Mode Register[12] pAIC->AIC_ICCR = (1<<AT91C_ID_IRQ0); // Clear the TC0 interrupt in AIC Interrupt Clear Command Register pAIC->AIC_IDCR = (0<<AT91C_ID_IRQ0); // Remove disable timer 0 interrupt in AIC Interrupt Disable Command Reg pAIC->AIC_IECR = (1<<AT91C_ID_IRQ0); // Enable the TC0 interrupt in AIC Interrupt Enable Command Register enableIRQ(); while (1) { Delay(200); if ((pPIO->PIO_ODSR & LED1) == LED1) { // read previous state of LED1 pPIO->PIO_CODR = LED1; } else { pPIO->PIO_SODR = LED1; } } } -------------------------------------------- button2isr.c: -------------------------------------------- #include "AT91SAM7S256.h" #include "board.h" void button2irqhandler (void) { volatile AT91PS_TC pTC = AT91C_BASE_TC0; // pointer to timer channel 0 register structure volatile AT91PS_PIO pPIO = AT91C_BASE_PIOA; // pointer to PIO register structure unsigned int dummy; // temporary dummy = pTC->TC_SR; // read TC0 Status Register to clear interrupt if ((pPIO->PIO_ODSR & LED2) == LED2) pPIO->PIO_CODR = LED2; // turn LED2 (DS2) on else pPIO->PIO_SODR = LED2; // turn LED2 (DS2) off } ------------------------------------------ Ich erhalte folgende Fehlermeldung: make -k all ..linking arm-elf-ld -v -Map main.map -Ttest123.cmd -o main.out crt.o main.o lowlevelinit.o libc.a libm.a libgcc.a GNU ld version 2.17 main.o: In function `main': L:\Workspace\test/main.c:33: undefined reference to `enableIRQ' L:\Workspace\test/main.c:43: undefined reference to `button2irqhandler' make: *** [main.out] Error 1 make: Target `all' not remade because of errors. Hat irgendjemand eine Ahnung? Gruß Tobias
1. der linker muss auch wissen, dass er button2isr.c mit benutzen muss, das weiß er bis jetzt noch nicht (siehe Output) 2. wo ist denn die Funktion enableIRQ ? Grüße lehmi
ZU 1. der Felher war in der makefile, dort hatte ich die ganzen
Interruptfiles noch nicht dazugefügt, dumm!
Seitdem ich das getan habe kann ich "build Project" ohne Fehler
durchführen
Zu 2.
Die Function habe ich mir von einem anderem Projekt "geklaut"
So ganz verstehen tue ich die nicht, aber dort funktioniert sie!
Hier ist sie:
unsigned _cpsr;
_cpsr = __get_cpsr();
__set_cpsr(_cpsr & ~IRQ_MASK);
return _cpsr;
Mittlerweile bringe ich das laufende Programm zum Absturz wenn ich die
Taste drücke......nach einer gewissen Zeit startet der Watchdog das
Programm von vorne! So als springt er irgendwo hin und bleibt dann
hängen.
Beim Neustart durch den Watchdog leuchtet die LED, die für den Interrupt
gedacht ist, ganz kurz auf! Auch so ein Rätsel was es zu lösen gilt.
