INFO:Xst:2117 wie "add an 'INIT' attribute" zu state?
OP #677472
Beim Synthetisieren des folgenden Code-Abschnitts gibt mir XST immer
folgende Info aus:
INFO:Xst:2117 - HDL ADVISOR - Mux Selector <current_state> of Case statement line 118 was re-encoded using one-hot encoding.
The case statement will be optimized (default statement optimization), but this optimization may lead to design initialization problems.
To ensure the design works safely, you can:
     - add an 'INIT' attribute on signal <current_state> (optimization is then done without any risk)
     - use the attribute 'signal_encoding user' to avoid onehot optimization
     - use the attribute 'safe_implementation yes' to force XST to perform a safe (but less efficient) optimization
Ich gehe davon aus, dass dies behoben werden sollte.
Hier nun also der Code-Abschnitt:
(stark zusammengekürzt, so ohne tieferen Sinn...)
    type state_type is (WAIT_ENABLE, WAIT_WINDOW_START, WAIT_MASK_START, WAIT_MASK_END, WAIT_WINDOW_END, WAIT_ENABLE_END );
    signal current_state                    : state_type := WAIT_ENABLE;
    signal next_state                       : state_type;
begin
    process(INT_CLK,INT_RESET)
    begin
        if INT_RESET = '1' then
            current_state   <= WAIT_ENABLE;
        elsif rising_edge(INT_CLK) then
            if READ_ENABLE = '1' then
                current_state <= next_state;
             else
            end if;
        end if;
    end process;
    -- state machine
    process (current_state, READ_ENABLE, WE_VALID_flag, WS_flag, MS_VALID_flag, MS_flag, ME_flag, WE_flag )
    begin
23
        -- Default-Werte, werden uebernommen wenn sonst nichts zutrifft, z.B. in IDLE
24
        BUSY_FLAG       <= '0';
25
        TRIGGER_FLAG    <= '0';
26
        next_state      <= WAIT_ENABLE;
27
28
        case current_state is
29
            when WAIT_ENABLE =>
30
31
                    next_state      <= WAIT_WINDOW_START;
32
                end if;
33
            when WAIT_WINDOW_START =>
34
                if WS_flag = '1' then
35
                    next_state      <= WAIT_WINDOW_END;
36
                end if;
37
            when WAIT_WINDOW_END =>
38
                if WE_flag = '1' then
39
                    next_state          <= WAIT_ENABLE_END;
40
            when WAIT_ENABLE_END =>
41
                if READ_ENABLE = '0' then
42
43
            when others =>
44
45
        end case;
46
    end process;
In diesem Fred ging es ums gleiche Thema:
Beitrag "folgende  HDL ADVISOR  Anweisung ?"
Demzufolge hätte ich wohl kein Problem zu erwarten, da ich ja mit Reset
arbeite.
In meinem Code habe ich aber dem current_state bereits einen Initialwert
verpasst. Warum taucht die Info dann immer noch auf?
Weiss da jemand Rat?
Gruss, Martin Kohler
Edit: Beitrag in der Breite reduziert, bessere Lesbarkeit...
#677505
Ich denke, diese Meldung tritt immer auf, wenn du dem Synthesizer die
Implementierung frei stellst. Du kannst das zwar auch selbst festlegen
(siehe Punkt 2 und 3 in der Meldung), aber das wuerde ich nicht machen.
Es handelt sich ja auch lediglich um ein Info, keine Warning, deswegen
kannst du das getrost ignorieren.
OP #677513
Ich möchte daher ja auch den ersten Hinweis beachten und das INIT
statement hinzufügen. Aber das klappt ja offenbar nicht ganz.
Wie genau ist das zu tun?
Ja, es ist nur eine Info. Aber das beantwortet leider meine Frage noch
nicht.
Danke für die bisherigen Antworten!
Gruss, Martin
OP #679379
Ich komme nochmals auf die State Encoding Frage zurück, denn ich habe im
Online-Tutorial auf www.vhdl-online.de in paar Angaben gefunden.
Ab dieser Seite: http://www.vhdl-online.de/tutorial/deutsch/t_222.htm
und folgende wird das Codieren von case statements erklärt.
Ich habe momentan ja am ehesten die Variante nach Kapitel 4.5.5 mit
One-Hot Encoding. Daraus folgt die Info wegen der "unsicheren"
Statemaschine - genau gemäss dem Tutorial.
Macht es nun Sinn, die Variante "4.5.7 Hand Coding" umzusetzen oder
macht das sowieso niemand?
Erfahrungen/Anregungen in dieser Sache? Codiert jemand die states "von
Hand" oder verwendet ihr (wie ich) einen selbst definierten type?
Gruss, Martin
#679386
Sowohl als auch:
Wenn man states mit guten Namen versehen kann, mache ich es. Manchmal
gibt es aber auch state machines, die einfach nur irgendetwas
abarbeiten, da nummeriere ich die states durch.
XST ist das reichlich egal, er waehlt in beiden Faellen das Encoding so,
wie es am besten passt, solange das nicht in den Optionen explizit
ausgeschaltet wird.
#679391
Ja natuerlich. Die wirst du immer bekommen, wen du nicht "FSM Encoding
Algorithm" auf "user" stellst.
Einen kleinen Vorteil hat die Kodierung per Hand: Man kann zum debuggen
den momentanen Zustand der state machine einfach auf einen Ausgang legen
und so im Betrieb beobachten.
  • [vhdl]VHDL-Code[/vhdl]
