ich habe mal wieder ein problem mit meinem MAC :-) .
NAchdem ich es geschafft habe den avr-gcc unter OS X zum laufen zu
bekommen, wollte ich das hex-File flsahen mit avrdude und meinem AVR910.
unter Windows klappt es einwandfrei ohne Fehlermeldung von avrdude und
dem hexfile.
Nur unter OS X bekomme ich folgende Meldung:
avrdude -p m32 -c avr910 -C /opt/local/etc/avrdude.con
f -P /dev/tty.usbserial-000033FD -U flash:w:"main.hex":i
Found programmer: Id = "AVR ISP"; type = S
Software Version = 3.8; Hardware Version = 1.2
Programmer supports auto addr increment.
Programmer supports the following devices:
Device code: 0x13 = AT90S1200
Device code: 0x20 = ATtiny84
Device code: 0x28 = AT90S4414
Device code: 0x30 = AT90S4433
Device code: 0x34 = AT90S2333
Device code: 0x38 = AT90S8515
Device code: 0x48 = (unknown)
Device code: 0x4c = AT90S2343
Device code: 0x51 = (unknown)
Device code: 0x55 = ATtiny12
Device code: 0x56 = ATtiny15
Device code: 0x68 = AT90S8535
Device code: 0x6c = AT90S4434
Device code: 0xffffff86 = (unknown)
Device code: 0xffffff87 = (unknown)
Device code: 0x01 = (unknown)
Device code: 0x04 = (unknown)
Device code: 0x05 = (unknown)
Device code: 0x06 = (unknown)
Device code: 0x07 = (unknown)
Device code: 0x08 = (unknown)
Device code: 0x09 = (unknown)
Device code: 0x0e = (unknown)
Device code: 0x1a = (unknown)
Device code: 0x0f = (unknown)
Device code: 0x1b = (unknown)
Device code: 0x14 = (unknown)
Device code: 0x1c = (unknown)
Device code: 0x1d = (unknown)
Device code: 0x23 = (unknown)
Device code: 0x31 = (unknown)
Device code: 0x33 = (unknown)
Device code: 0x35 = (unknown)
Device code: 0x37 = (unknown)
Device code: 0x39 = (unknown)
Device code: 0x3d = (unknown)
Device code: 0x3e = (unknown)
Device code: 0x57 = (unknown)
Device code: 0x3a = (unknown)
Device code: 0x3b = ATMEGA8515
Device code: 0x41 = ATMEGA103
Device code: 0x43 = (unknown)
Device code: 0x44 = ATMEGA128
Device code: 0x45 = (unknown)
Device code: 0x46 = ATMEGA64
Device code: 0x5e = ATtiny2313
Device code: 0x60 = ATMEGA161
Device code: 0x61 = (unknown)
Device code: 0x62 = (unknown)
Device code: 0x63 = ATMEGA162
Device code: 0x64 = ATMEGA163
Device code: 0x66 = (unknown)
Device code: 0x69 = (unknown)
Device code: 0x6a = ATMEGA8535
Device code: 0x72 = ATMEGA32
Device code: 0x73 = (unknown)
Device code: 0x74 = ATMEGA6450
Device code: 0x75 = ATMEGA6490
Device code: 0x76 = (unknown)
Device code: 0x77 = ATMEGA8
Device code: 0x78 = (unknown)
Device code: 0x79 = ATMEGA169
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100%
0.02s
avrdude: Device signature = 0x1e9502
avrdude: safemode: Verify error - unable to read lfuse properly.
Programmer may not be reliable.
avrdude: safemode: To protect your AVR the programming will be aborted
avrdude done. Thank you.
Was kann es sein??
world
Die Baudrate brauchte ich unter Windows auch nicht einstellen!! Ist das unter OS X anders?? MfG world
also ich musste sie bei mir unter OSX angeben. Wie es unter Windows ist weis ich nicht.
So habe es mit -b 9600 usw. probiert, alles beim alten. Leoder ist auch noch ein Problem mit avrdude, nach ein paarmal ausprobieren, gibt es folgende fehlermeldung, und er kann nicht mehr auf den avr910 zugreifen!? avrdude -p m32 -c avr910 -b 9600 -P /dev/tty.usbserial-000033FD -U flash:w:"main.hex":i avrdude: avr910_recv(): programmer is not responding
Ich würde mal raten, dass du eine zu alte avrdude-Version hast. https://savannah.nongnu.org/bugs/index.php?18803 ...wenn mich jetzt nicht alles täuscht. Du kannst ein "-u" mit angeben, um erstmal so weiterarbeiten zu können.
SUPER DANKE !!!!! mit dem -u hat geholfen!! Kann jetzt erstaml so weiterarbieten :-) Vielen DANK! Bin aber der Meinung, das ich die neuste Version habe, aber ich schau mal nach. MfG world
Ruf avrdude mit -v auf, dann sagt es dir die Version. Aktuell ist 5.5. OK, die ist knapp einen Monat alt. Der Bug war aber schon in 5.4 repariert.
