Forum: Mikrocontroller und Digitale Elektronik LPC2469 Inbetriebnahme
von mek (Gast)
ich habe probleme bei der Inbetriebnahme des NXP LPC2468,
der startup code passt denke ich mit meinem speicher nicht überein!
an welcher stelle muss ich den code ändern und wie?
Danke!
 * Copyright (c) 2001, 2002 Rowley Associates Limited.                       *
 * This file may be distributed under the terms of the License Agreement     *
 * provided with this software.                                              *
 * THIS FILE IS PROVIDED AS IS WITH NO WARRANTY OF ANY KIND, INCLUDING THE   *
 * WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. *
 *                           Preprocessor Definitions
 * VECTORED_IRQ_INTERRUPTS
 *   Enable vectored IRQ interrupts. If defined, the PC register will be loaded
 *   with the contents of the VICVectAddr register on an IRQ exception.
 * STARTUP_FROM_RESET
 *   If defined, the program will startup from power-on/reset. If not defined
23
 *   the program will just loop endlessly from power-on/reset.
24
25
 *   This definition is not defined by default on this target because the
26
 *   debugger is unable to reset this target and maintain control of it over the
27
 *   JTAG interface. The advantage of doing this is that it allows the debugger
28
 *   to reset the CPU and run programs from a known reset CPU state on each run.
29
 *   It also acts as a safety net if you accidently download a program in FLASH
30
 *   that crashes and prevents the debugger from taking control over JTAG
31
 *   rendering the target unusable over JTAG. The obvious disadvantage of doing
32
 *   this is that your application will not startup without the debugger.
33
34
 *   We advise that on this target you keep STARTUP_FROM_RESET undefined whilst
35
 *   you are developing and only define STARTUP_FROM_RESET when development is
36
 *   complete.
37
38
 * PLLCFG_VAL
39
40
 *   Override the default PLL configuration by defining PLLCFG_VAL.
41
42
 * CCLKCFG_VAL
43
44
 *   Override the default CPU clock divider configuration by defining
45
 *   CCLKCFG_VAL.
46
47
 * NO_PLL_ENABLE
48
49
 *   If defined, the PLL will not be enabled.
50
51
 * USBCLKCFG_VAL
52
53
 *   Override the default USB clock divider configuration by defining
54
 *   USBCLKCFG_VAL.
55
56
 * MAMCR_VAL & MAMTIM_VAL
57
58
 *   Override the default MAM configuration (fully enabled, 3 fetch cycles)
59
 *   by defining MAMCR_VAL and MAMTIM_VAL.
60
61
 * SRAM_EXCEPTIONS
62
63
 *   If defined, enable copying and re-mapping of interrupt vectors from User
64
 *   FLASH to SRAM. If undefined, interrupt vectors will be mapped in User
65
 *   FLASH.
66
67
68
69
#include <targets/LPC2000.h>
70
71
#if OSCILLATOR_CLOCK_FREQUENCY==12000000
72
73
/* Fosc = 12Mhz, Fcco = 288Mhz, cclk = 57.6Mhz */
74
#ifndef PLLCFG_VAL
75
#define PLLCFG_VAL ((11 << PLLCFG_MSEL_BIT) | (0 << PLLCFG_NSEL_BIT))
76
#endif
77
#ifndef CCLKCFG_VAL
78
#define CCLKCFG_VAL 4
79
#endif
80
#ifndef USBCLKCFG_VAL
81
#define USBCLKCFG_VAL 5
82
#endif
83
84
#endif
85
86
#ifndef MAMCR_VAL
87
#define MAMCR_VAL 2
88
#endif
89
90
#ifndef MAMTIM_VAL
91
#define MAMTIM_VAL 3
92
#endif
93
94
  .section .vectors, "ax"
95
  .code 32
96
  .align 0
97
  .global _vectors
98
  .global reset_handler
99
100
101
 * Exception Vectors                                                         *
102
103
_vectors:
104
  ldr pc, [pc, #reset_handler_address - . - 8]  /* reset */
105
  ldr pc, [pc, #undef_handler_address - . - 8]  /* undefined instruction */
106
  ldr pc, [pc, #swi_handler_address - . - 8]    /* swi handler */
107
  ldr pc, [pc, #pabort_handler_address - . - 8] /* abort prefetch */
108
  ldr pc, [pc, #dabort_handler_address - . - 8] /* abort data */
109
#ifdef VECTORED_IRQ_INTERRUPTS
110
  .word 0xB9206E58                              /* boot loader checksum */
111
  ldr pc, [pc, #-0x120]                         /* irq handler */
112
#else
113
  .word 0xB8A06F60                              /* boot loader checksum */
114
  ldr pc, [pc, #irq_handler_address - . - 8]    /* irq handler */
115
#endif
116
  ldr pc, [pc, #fiq_handler_address - . - 8]    /* fiq handler */
117
118
reset_handler_address:
119
#ifdef STARTUP_FROM_RESET
120
  .word reset_handler
121
#else
122
  .word reset_wait
123
#endif
124
undef_handler_address:
125
  .word undef_handler
126
swi_handler_address:
127
  .word swi_handler
128
pabort_handler_address:
129
  .word pabort_handler
130
dabort_handler_address:
131
  .word dabort_handler
132
#ifndef VECTORED_IRQ_INTERRUPTS
133
irq_handler_address:
134
  .word irq_handler
135
#endif
136
fiq_handler_address:
137
  .word fiq_handler
138
139
  .section .init, "ax"
140
  .code 32
141
  .align 0
142
143
144
145
 * Default exception handlers                                                 *
146
147
148
reset_handler:
149
  ldr r0, =SCB_BASE
150
151
#if defined(PLLCFG_VAL) && !defined(NO_PLL_ENABLE)
152
  /* Configure PLL Multiplier/Divider */
153
  ldr r1, [r0, #PLLSTAT_OFFSET]
154
  tst r1, #PLLSTAT_PLLC
155
  beq 1f
156
157
  /* Disconnect PLL */
158
  ldr r1, =PLLCON_PLLE
159
  str r1, [r0, #PLLCON_OFFSET]
160
  mov r1, #0xAA
161
  str r1, [r0, #PLLFEED_OFFSET]
162
  mov r1, #0x55
163
164
1:
165
  /* Disable PLL */
166
  ldr r1, =0
167
168
  mov r1, #0xAA
169
170
  mov r1, #0x55
171
172
173
  /* Enable main oscillator */
174
  ldr r1, [r0, #SCS_OFFSET]
175
  orr r1, r1, #SCS_OSCEN
176
  str r1, [r0, #SCS_OFFSET]
177
1:
178
179
  tst r1, #SCS_OSCSTAT
180
  beq 1b
181
182
  /* Select main oscillator as the PLL clock source */
183
  ldr r1, =1
184
  str r1, [r0, #CLKSRCSEL_OFFSET]
185
186
  /* Set PLLCFG */
187
  ldr r1, =PLLCFG_VAL
188
  str r1, [r0, #PLLCFG_OFFSET]
189
  mov r1, #0xAA
190
191
  mov r1, #0x55
192
193
194
  /* Enable PLL */
195
196
197
  mov r1, #0xAA
198
199
  mov r1, #0x55
200
201
202
#ifdef CCLKCFG_VAL
203
  /* Set the CPU clock divider */
204
  ldr r1, =CCLKCFG_VAL
205
  str r1, [r0, #CCLKCFG_OFFSET]
206
#endif
207
208
#ifdef USBCLKCFG_VAL
209
210
  ldr r1, =USBCLKCFG_VAL
211
  str r1, [r0, #USBCLKCFG_OFFSET]
212
#endif
213
214
  /* Wait for PLL to lock */
215
1:
216
217
  tst r1, #PLLSTAT_PLOCK
218
  beq 1b
219
  /* PLL Locked, connect PLL as clock source */
220
  mov r1, #(PLLCON_PLLE | PLLCON_PLLC)
221
222
  mov r1, #0xAA
223
224
  mov r1, #0x55
225
226
  /* Wait for PLL to connect */
227
1:
228
229
230
  beq 1b
231
#endif
232
233
  /* Initialise memory accelerator module */
234
  mov r1, #0
235
  str r1, [r0, #MAMCR_OFFSET]
236
  ldr r1, =MAMTIM_VAL
237
  str r1, [r0, #MAMTIM_OFFSET]
238
  ldr r1, =MAMCR_VAL
239
240
241
#if defined(SRAM_EXCEPTIONS)
242
  /* Copy exception vectors into SRAM */
243
  mov r8, #0x40000000
244
  ldr r9, =_vectors
245
  ldmia r9!, {r0-r7}
246
  stmia r8!, {r0-r7}
247
  ldmia r9!, {r0-r6}
248
  stmia r8!, {r0-r6}
249
250
  /* Re-map interrupt vectors from SRAM */
251
  ldr r0, =SCB_BASE
252
  mov r1, #2 /* User RAM Mode. Interrupt vectors are re-mapped from SRAM */
253
  str r1, [r0, #MEMMAP_OFFSET]
254
#endif /* SRAM_EXCEPTIONS */
255
256
  b _start
257
258
#ifndef STARTUP_FROM_RESET
259
reset_wait:
260
  b reset_wait
261
#endif
262
263
264
265
266
 * These are declared weak symbols so they can be redefined in user code.     *
267
268
269
undef_handler:
270
  b undef_handler
271
272
swi_handler:
273
  b swi_handler
274
275
pabort_handler:
276
  b pabort_handler
277
278
dabort_handler:
279
  b dabort_handler
280
281
fiq_handler:
282
  b fiq_handler
283
284
irq_handler:
285
  b irq_handler
286
287
  .weak undef_handler, swi_handler, pabort_handler, dabort_handler, fiq_handler, irq_handler
von Robert T. (robertteufel)
Was meinst Du mit "der Code passt nicht rein?" Groessenmaessig passt der
locker rein.
Ich hab mir den Code kurz angesehen und Du solltest keinen ungeraden
Teilerfaktor fuer die PLL (5) benuetzen.
Der PLL-Teiler sollte also 6 sein und somit ergibt sich eine CPU
Frequenz von 48 MHz. Falls es bereits ein Rev "B" ist, kannst Du auch
mit Teilerfaktor 4 und 72 MHz arbeiten.
Robert
