1 | /*****************************************************
2 | This program was produced by the
3 | CodeWizardAVR V1.25.1 Standard
4 | Automatic Program Generator
5 | © Copyright 1998-2006 Pavel Haiduc, HP InfoTech s.r.l.
6 | http://www.hpinfotech.com
7 |
8 | Chip type : ATmega8515L
9 | Program type : Application
10 | Clock frequency : 4,000000 MHz
11 | Memory model : Small
12 | External SRAM size : 0
13 | Data Stack size : 128
14 | *****************************************************/
15 |
16 | #include <mega8515.h>
17 | #include <stdio.h>
18 |
19 | // Initialisierung Senden & Empfangen über USART-Schnittstelle
20 | //------------------------------------------------------------------------
21 | #define RXB8 1
22 | #define TXB8 0
23 | #define UPE 2
24 | #define OVR 3
25 | #define FE 4
26 | #define UDRE 5
27 | #define RXC 7
28 |
29 | #define FRAMING_ERROR (1<<FE)
30 | #define PARITY_ERROR (1<<UPE)
31 | #define DATA_OVERRUN (1<<OVR)
32 | #define DATA_REGISTER_EMPTY (1<<UDRE)
33 | #define RX_COMPLETE (1<<RXC)
34 |
35 |
36 | // USART Receiver buffer
37 | #define RX_BUFFER_SIZE 8
38 | char rx_buffer[RX_BUFFER_SIZE];
39 |
40 | #if RX_BUFFER_SIZE<256
41 | unsigned char rx_wr_index,rx_rd_index,rx_counter;
42 | unsigned char notify=0x00;
43 | #else
44 | unsigned int rx_wr_index,rx_rd_index,rx_counter;
45 | #endif
46 |
47 | // This flag is set on USART Receiver buffer overflow
48 | bit rx_buffer_overflow;
49 |
50 | // USART Receiver interrupt service routine
51 | interrupt [USART_RXC] void usart_rx_isr(void)
52 | {
53 |
54 | char status,data;
55 | status=UCSRA;
56 | notify=status;
57 | data=UDR;
58 | if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
59 | {
60 | rx_buffer[rx_wr_index]=data;
61 |
62 | if (++rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0;
63 | if (++rx_counter == RX_BUFFER_SIZE)
64 | {
65 | rx_counter=0;
66 | rx_buffer_overflow=1;
67 | };
68 | };
69 | }
70 |
71 | #ifndef _DEBUG_TERMINAL_IO_
72 | // Get a character from the USART Receiver buffer
73 | #define _ALTERNATE_GETCHAR_
74 | #pragma used+
75 |
76 |
77 |
78 | char getchar(void)
79 | {
80 | char data;
81 | while (rx_counter==0);
82 | data=rx_buffer[rx_rd_index];
83 | if (++rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
84 | #asm("cli")
85 | --rx_counter;
86 | #asm("sei")
87 | return data;
88 | }
89 | #pragma used-
90 | #endif
91 |
92 |
93 |
94 | // USART Transmitter buffer
95 | #define TX_BUFFER_SIZE 8
96 | char tx_buffer[TX_BUFFER_SIZE];
97 |
98 | #if TX_BUFFER_SIZE<256
99 | unsigned char tx_wr_index,tx_rd_index,tx_counter;
100 | #else
101 | unsigned int tx_wr_index,tx_rd_index,tx_counter;
102 | #endif
103 |
104 |
105 |
106 |
107 | // USART Transmitter interrupt service routine
108 | interrupt [USART_TXC] void usart_tx_isr(void)
109 | {
110 | if (tx_counter)
111 | {
112 | --tx_counter;
113 | UDR=tx_buffer[tx_rd_index];
114 | if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0;
115 | };
116 | }
117 |
118 | #ifndef _DEBUG_TERMINAL_IO_
119 | // Write a character to the USART Transmitter buffer
120 | #define _ALTERNATE_PUTCHAR_
121 | #pragma used+
122 |
123 |
124 |
125 |
126 | void putchar(char c)
127 | {
128 | while (tx_counter == TX_BUFFER_SIZE);
129 | #asm("cli")
130 | if (tx_counter || ((UCSRA & DATA_REGISTER_EMPTY)==0))
131 | {
132 | tx_buffer[tx_wr_index]=c;
133 | if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0;
134 | ++tx_counter;
135 | }
136 | else
137 | UDR=c;
138 | #asm("sei")
139 | }
140 | #pragma used-
141 | #endif
142 | //------------------------------------------------------------------------
143 |
144 |
145 | // Declare your global variables here
146 |
147 |
148 | void main(void)
149 | {
150 | // Declare your local variables here
151 | unsigned char taster=0xFF;
152 | unsigned char led=0xFF;
153 | unsigned char led_alt=0xFF;
154 |
155 |
156 | // Input/Output Ports initialization
157 | PORTA=0xFF;
158 | DDRA=0x00;
159 |
160 | PORTB=0xFF;
161 | DDRB=0xFF;
162 |
163 | // Timer/Counter 0 initialization
164 | TCCR0=0x00;
165 | TCNT0=0x00;
166 | OCR0=0x00;
167 |
168 | // Timer/Counter 1 initialization
169 | TCCR1A=0x00;
170 | TCCR1B=0x00;
171 | TCNT1H=0x00;
172 | TCNT1L=0x00;
173 | ICR1H=0x00;
174 | ICR1L=0x00;
175 | OCR1AH=0x00;
176 | OCR1AL=0x00;
177 | OCR1BH=0x00;
178 | OCR1BL=0x00;
179 |
180 | // External Interrupt(s) initialization
181 | MCUCR=0x00;
182 | EMCUCR=0x00;
183 |
184 | // Timer(s)/Counter(s) Interrupt(s) initialization
185 | TIMSK=0x00;
186 |
187 | // USART initialization
188 | // Communication Parameters: 8 Data, 1 Stop, No Parity
189 | // USART Receiver: On
190 | // USART Transmitter: On
191 | // USART Mode: Asynchronous
192 | // USART Baud rate: 9600
193 | UCSRA=0x00;
194 | UCSRB=0xD8;
195 | UCSRC=0x86;
196 | UBRRH=0x00;
197 | UBRRL=0x17;
198 |
199 | // Analog Comparator initialization
200 | ACSR=0x80;
201 |
202 | // Global enable interrupts
203 | #asm("sei")
204 |
205 |
206 | while (1)
207 | {
208 | // B: LED A: TASTER
209 |
210 | // solange notify kleiner 128: Board Modus
211 | // d.h. abfrage ob erstes Bit in UCSRA gesetzt ist (Daten empfangen)
212 | while (notify<0x80){
213 | // LED: wenn änderung zum vorigen schleifendurchlauf wird LED status an PC geschickt
214 | led=PINB;
215 | if (led_alt!=led){
216 | putchar(led);
217 | }
218 | led_alt=led;
219 |
220 | //Board mode
221 | PORTB=PINA;
222 | }
223 |
224 |
225 | // solange kein Taster gedrückt wird: PC Modus
226 | // hier kommt man nicht mehr raus! Idee: rauswurf durch tasterdruck am board...
227 | while (PINA==0xFF){
228 | // LED: wenn änderung zum vorigen schleifendurchlauf wird LED status an PC geschickt
229 | led=PINB;
230 | if (led_alt!=led){
231 | putchar(led);
232 | }
233 | led_alt=led;
234 |
235 | //PC Mode
236 | PORTB=getchar();
237 | }
238 |
239 | notify=0x00;
240 |
241 | };
242 | }
